I’ve a Rock5B (powered by a traditional PC PSU) with two disks attached through this adapter: an SSD and an HD (Exos X14, 10TB).
The SSD never gave me a single problem (formatted as EXT4), instead the HD cyclically stopped working ending in a state where even fsck wasn’t helping (luckily I make daily backups).
I thought it was due to bcachefs (the HD was formatted in that FS) so after having to reformat 2 times I chose to try a different FS (xfs, which should be much more stable) but still after some days I’m starting to see again weird errors with dmesg:
[40602.032058] ata4.00: exception Emask 0x10 SAct 0xffffc0 SErr 0x49d0000 action 0xe frozen
[40602.032778] ata4.00: irq_stat 0x00400000, PHY RDY changed
[40602.033250] ata4: SError: { PHYRdyChg CommWake 10B8B Dispar LinkSeq DevExch }
[40602.033877] ata4.00: failed command: READ FPDMA QUEUED
[40602.034326] ata4.00: cmd 60/20:30:10:1b:7c/00:00:01:03:00/40 tag 6 ncq dma 16384 in
res 40/00:01:01:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[40602.035695] ata4.00: status: { DRDY }
[40602.036035] ata4.00: failed command: READ FPDMA QUEUED
[40602.036483] ata4.00: cmd 60/20:38:30:1b:7c/00:00:01:03:00/40 tag 7 ncq dma 16384 in
res 40/00:00:00:4f:c2/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
[40602.037849] ata4.00: status: { DRDY }
[40602.038172] ata4.00: failed command: READ FPDMA QUEUED
[40602.038620] ata4.00: cmd 60/20:40:50:1b:7c/00:00:01:03:00/40 tag 8 ncq dma 16384 in
res 40/00:01:00:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[40602.039991] ata4.00: status: { DRDY }
[40602.040314] ata4.00: failed command: READ FPDMA QUEUED
[40602.040762] ata4.00: cmd 60/20:48:70:1b:7c/00:00:01:03:00/40 tag 9 ncq dma 16384 in
[40602.042127] ata4.00: status: { DRDY }
Or
[40619.286796] I/O error, dev sda, sector 12909812592 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
[40619.287612] sd 3:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=18s
[40619.287615] sd 3:0:0:0: [sda] tag#10 Sense Key : 0x5 [current]
[40619.287618] sd 3:0:0:0: [sda] tag#10 ASC=0x21 ASCQ=0x4
[40619.287621] sd 3:0:0:0: [sda] tag#10 CDB: opcode=0x88 88 00 00 00 00 03 01 7c 1b 90 00 00 00 20 00 00
According to smartctl the disk is good but starting the long test the test itself fails. Instead the smart metrics seems ok. I’ve tried changing the cable but it doesn’t help. I’ve currently attached to disk to another machine where I’m running the long test without any error in dmesg, so I’m starting to think that it may be the controller’s fault (even if for the SSD it works flawlessly?). Otherwise it could be a power issue but I can’t see how, I don’t remember the exact specifics of the PSU but I removed it from a PC which certainly consumed more than the Rock5B + 1 SSD + 1 HD + 1 fan.
I’m tempted to buy another controller and see what happens but perhaps someone can suggest a model which works for sure?
Otherwise it could be a software problem but I’ve no idea how to investigate in that direction. I’m running NixOS (mainline Linux 6.11) if it can help.
