I have a problem with the SPI flash.
I tested on 36 rockpi 4C, on 30 I had no problem the SPI is flashing (so my procedure is ok), but the 6 others do not work.
Here are my steps:
- installation of a jumper for the CLK of the spinnaker.
- usbA OTG connection
- card ignition (via usb-c)
- I take off the jumper
- rk ld> OK spi found (
rkdeveloptool ld DevNo=1 Vid=0x2207,Pid=0x330c,LocationID=1401 Maskrom) - bootload rk> OK (
sudo rkdeveloptool db /Users/aaa/Desktop/rockpi/spi/out/u-boot/spi/rk3399_loader_spinor_v1.20.126.bin > Downloading bootloader succeeded.) - rk wl 0 …> OK (
sudo rkdeveloptool wl 0 /Users/aaa/Desktop/rockpi/spi/out/u-boot/spi/uboot-trust-spi.img > Write LBA from file (100%)) - rk rd> Reset ok (
sudo rkdeveloptool rd > Reset Device OK.)
if I leave plugged in I have my uboot which launches on the screen! awesome. but if I cut the power supply to the card and the restart the spinnaker u-boot does not start.
Namely that this same u-boot and loader works very well on the other 30 RockPi 4C
do you have an idea to solve this problem? thank you.
