I have the same issue with the Radxa Rock 5C Lite w/16GB and Radxa 4K Camera/sensor (IMX415) connected to the 4 lane MIPI-CSI interface.
I ran three 4k@60 tests using gst-launch-1.0 which showed:
- Camera source only (
v4l2src → fakesink):
600 frames in 15.2s ⇒ about 39.5 fps max ingest.
- Encoder only (
videotestsrc → mpph265enc → fakesink):
600 frames in 58.0s ⇒ about 10.3 fps encode throughput.
- Real pipeline (
v4l2src → mpph265enc → filesink):
600 buffers processed in ~10.4s pipeline runtime, but file decodes to only 38 frames (avg 25 fps metadata quirk). This indicates heavy dropping/backpressure/unstable timestamping in encoded output path.
Looks like the stack cannot sustain 4K@60 because mpph265enc throughput is the dominant bottleneck (≈10 fps in isolation). The camera path is better than the encoder path.
I ran a 4k@30 test which failed with a RgaBlit(1513) RGA_BLIT fail: Cannot allocate memory and then it stated a Bus error.
I also ran 2k(QHD)@60, 1440@60 and 1080@60 tests… all of which passed so, it looks like the 4k capture is what’s broken on the board. Sadly, I’m going to have to return a bunch of these boards due to false advertising.
SYSTEM DIAGNOSTIC REPORT
Generated : 2026-06-10T05:27:45Z
Hostname : cam001
OPERATING SYSTEM
— OS release —
PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)”
NAME=“Debian GNU/Linux”
VERSION_ID=“12”
VERSION=“12 (bookworm)”
VERSION_CODENAME=bookworm
ID=debian
HOME_URL=“https://www.debian.org/”
SUPPORT_URL=“https://www.debian.org/support”
BUG_REPORT_URL=“https://bugs.debian.org/”
— Kernel version —
6.1.84-8-rk2410
— Full uname —
Linux cam001 6.1.84-8-rk2410 #8 SMP Thu Oct 16 07:07:35 UTC 2025 aarch64 GNU/Linux
— Architecture —
aarch64
— LSB release —
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
— Kernel cmdline —
root=UUID=a59c\*\*\*\*-**-**-\*\*\*\*-\*\*\*\*\*\*\*\*f8a8 console=ttyFIQ0,1500000n8 quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 androidboot.fwver=ddr-v1.16-9fffbe1e78,bl31-v1.45,uboot-17.09-32-8-07/02/2024
SYSTEM UPTIME & LOAD
— Uptime —
00:27:45 up 7 min, 0 user, load average: 0.05, 0.16, 0.11
— Load average —
0.05 0.16 0.11 1/291 1678
CPU
— CPU info (summary) —
Architecture: aarch64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 6
On-line CPU(s) list: 0-5
Vendor ID: ARM
Model name: -
Model: Rockchip RK3588S
Thread(s) per core: 0
Core(s) per socket: 0
Socket(s): 0
Stepping: 0x2
BogoMIPS: 48.00
Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
Model name: -
Model: 0
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
CPU(s) scaling MHz: 100%
CPU max MHz: 1800.0000
CPU min MHz: 408.0000
BogoMIPS: 48.00
Model name: -
Socket(s): 0
Stepping: 0x2
Model name: -
Model: 0
Socket(s): 1
BogoMIPS: 48.00
Model name: -
Socket(s): 0
Stepping: 0x2
Model name: -
Model: 0
Socket(s): 1
BogoMIPS: 48.00
Model name: -
Socket(s): 0
Stepping: 0x2
Model name: -
Model: 0
Socket(s): 1
BogoMIPS: 48.00
Model name: -
Socket(s): 0
Stepping: 0x4
Model name: -
Model: 0
Socket(s): 1
CPU(s) scaling MHz: 27%
CPU max MHz: 2256.0000
BogoMIPS: 48.00
Model name: -
Socket(s): 0
Stepping: 0x4
Model name: -
Model: 0
Socket(s): 1
Caches (sum of all):
L1d: 256 KiB (6 instances)
L1i: 256 KiB (6 instances)
L2: 1.5 MiB (6 instances)
L3: 3 MiB (1 instance)
— CPU details (/proc) —
processor : 0
BogoMIPS : 48.00
Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
cpu model : Rockchip RK3588S
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x2
CPU part : 0xd05
CPU revision : 0
processor : 1
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x2
CPU part : 0xd05
CPU revision : 0
processor : 2
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x2
CPU part : 0xd05
CPU revision : 0
processor : 3
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x2
CPU part : 0xd05
CPU revision : 0
processor : 4
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x4
CPU part : 0xd0b
CPU revision : 0
processor : 5
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x4
CPU part : 0xd0b
CPU revision : 0
Serial : 16e\*\*\*\*\*\*\*\*\*\*\*\*867
— CPU frequency —
1800000
— CPU topology —
CPU L1d:L1i:L2:L3 ONLINE
0 0:0:0:0 yes
1 1:1:1:0 yes
2 2:2:2:0 yes
3 3:3:3:0 yes
4 4:4:4:0 yes
5 5:5:5:0 yes
— Thermal zones —
soc-thermal: 41.6°C
bigcore0-thermal: 40.6°C
bigcore1-thermal: 41.6°C
littlecore-thermal: 41.6°C
center-thermal: 40.6°C
gpu-thermal: 40.6°C
npu-thermal: 40.6°C
MEMORY
— Memory overview —
total used free shared buff/cache available
Mem: 15Gi 1.1Gi 14Gi 1.6Mi 393Mi 14Gi
Swap: 7.8Gi 0B 7.8Gi
— Memory details —
MemTotal: 16344884 kB
MemFree: 14946644 kB
MemAvailable: 15184960 kB
Buffers: 32228 kB
Cached: 303844 kB
SwapCached: 0 kB
Active: 86092 kB
Inactive: 994936 kB
Active(anon): 932 kB
Inactive(anon): 745628 kB
Active(file): 85160 kB
Inactive(file): 249308 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 8172440 kB
SwapFree: 8172440 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 744592 kB
Mapped: 131572 kB
Shmem: 1644 kB
KReclaimable: 67224 kB
Slab: 145812 kB
SReclaimable: 67224 kB
SUnreclaim: 78588 kB
KernelStack: 4760 kB
PageTables: 12652 kB
SecPageTables: 0 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 16344880 kB
Committed_AS: 1528800 kB
VmallocTotal: 133143592960 kB
VmallocUsed: 54752 kB
VmallocChunk: 0 kB
Percpu: 2016 kB
CmaTotal: 8192 kB
CmaAllocated: 2048 kB
CmaReleased: 6144 kB
CmaFree: 5740 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
STORAGE
— Block devices —
NAME SIZE TYPE FSTYPE MOUNTPOINT MODEL SERIAL
mmcblk1 58G disk 0xda446b07
├─mmcblk1p1 16M part vfat /config
├─mmcblk1p2 300M part vfat /boot/efi
└─mmcblk1p3 57.6G part ext4 /
zram0 7.8G disk \[SWAP\]
— Disk usage —
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 7.8G 8.0K 7.8G 1% /dev
tmpfs tmpfs 1.6G 1.6M 1.6G 1% /run
/dev/mmcblk1p3 ext4 57G 13G 42G 24% /
tmpfs tmpfs 7.8G 0 7.8G 0% /dev/shm
tmpfs tmpfs 5.0M 12K 5.0M 1% /run/lock
/dev/mmcblk1p2 vfat 300M 0 300M 0% /boot/efi
/dev/mmcblk1p1 vfat 16M 404K 16M 3% /config
//nas01/data cifs 12T 7.3T 4.0T 65% /mnt/data
tmpfs tmpfs 1.6G 4.0K 1.6G 1% /run/user/1000
— Mount table —
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=8152500k,nr_inodes=2038125,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=1634492k,mode=755)
/dev/mmcblk1p3 on / type ext4 (rw,relatime)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=31580)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /boot/efi type autofs (rw,relatime,fd=48,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=171)
systemd-1 on /config type autofs (rw,relatime,fd=49,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=174)
systemd-1 on /mnt/data type autofs (rw,relatime,fd=50,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=177)
ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
/dev/mmcblk1p2 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro,x-systemd.automount)
/dev/mmcblk1p1 on /config type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro,x-systemd.automount)
//nas01/data on /mnt/data type cifs (rw,relatime,vers=3.1.1,cache=strict,username=radxa,uid=1000,noforceuid,gid=1000,noforcegid,addr=192.168.xx.xx,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1,\_netdev,x-systemd.automount)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=1634488k,nr_inodes=408622,mode=700,uid=1000,gid=1000)
— Block device UUIDs —
(not available or requires elevated privileges)
NETWORK
— Network interfaces —
lo UNKNOWN 127.0.0.1/8 ::1/128
end1 UP redacted
wlan0 DOWN
— IP routing table —
default via 192.168.xx.xx dev end1 proto dhcp src 192.168.xx.xx metric 100
192.168.xx.xx/24 dev end1 proto kernel scope link src 192.168.xx.xx metric 100
— Link details —
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 promiscuity 0 allmulti 0 minmtu 0 maxmtu 0 addrgenmode eui64 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535 tso_max_size 524280 tso_max_segs 65535 gro_max_size 65536
2: end1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether xx:00:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff promiscuity 0 allmulti 0 minmtu 46 maxmtu 9000 addrgenmode none numtxqueues 8 numrxqueues 8 gso_max_size 65536 gso_max_segs 65535 tso_max_size 65536 tso_max_segs 65535 gro_max_size 65536 parentbus platform parentdev fe1c0000.ethernet
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DORMANT group default qlen 1000
link/ether xx:00:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff promiscuity 0 allmulti 0 minmtu 68 maxmtu 1500 addrgenmode none numtxqueues 257 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535 tso_max_size 65536 tso_max_segs 65535 gro_max_size 65536 parentbus usb parentdev 7-1.3
— Listening sockets —
State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
LISTEN 0 4096 0.0.0.0:111 0.0.0.0:\*
LISTEN 0 32 0.0.0.0:53 0.0.0.0:\*
LISTEN 0 128 0.0.0.0:22 0.0.0.0:\*
LISTEN 0 128 127.0.0.1:42493 0.0.0.0:\* users:((“code-3c631b164c”,pid=1041,fd=11))
LISTEN 0 128 0.0.0.0:7000 0.0.0.0:\* users:((“camera-controll”,pid=888,fd=3))
LISTEN 0 128 127.0.0.1:38675 0.0.0.0:\* users:((“code-3c631b164c”,pid=964,fd=10))
LISTEN 0 4096 \[::\]:111 \[::\]:\*
LISTEN 0 32 \[::\]:53 \[::\]:\*
LISTEN 0 128 \[::\]:22 \[::\]:\*
— Hostname file —
cam001
PCI DEVICES
— PCI devices —
USB DEVICES
— USB devices —
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 004: ID a69c:8d81 AICSemi AIC 8800D80
Bus 007 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
— USB tree —
/: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
|\_\_ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|\_\_ Port 3: Dev 4, If 0, Class=Wireless, Driver=aic_btusb, 480M
|\_\_ Port 3: Dev 4, If 1, Class=Wireless, Driver=aic_btusb, 480M
|\_\_ Port 3: Dev 4, If 2, Class=Vendor Specific Class, Driver=aic8800_fdrv, 480M
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
CAMERA / V4L2 DEVICES
— V4L2 devices —
rkisp-statistics (platform: rkisp):
/dev/video18
/dev/video19
rkcif (platform:rkcif-mipi-lvds2):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
/dev/video4
/dev/video5
/dev/video6
/dev/video7
/dev/video8
/dev/video9
/dev/video10
/dev/media0
rkisp_mainpath (platform:rkisp0-vir0):
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video17
/dev/media1
— V4L2 device caps —
Driver Info:
Driver name : rkcif
Card type : rkcif
Bus info : platform:rkcif-mipi-lvds2
Driver version : 6.1.84
Capabilities : 0x84201000
Video Capture Multiplanar
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04201000
Streaming
Extended Pix Format
Media Driver Info:
Driver name : rkcif
Model : rkcif-mipi-lvds2
Serial :
Media version : 6.1.84
Hardware revision: 0x00000000 (0)
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Pad 0x01000004 : 0: Sink
Link 0x02000043: from remote pad 0x100002f of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data, Enabled
Link 0x02000059: from remote pad 0x1000030 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Link 0x0200006f: from remote pad 0x1000031 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Link 0x02000085: from remote pad 0x1000032 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Link 0x0200009b: from remote pad 0x1000033 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Link 0x020000b1: from remote pad 0x1000034 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Link 0x020000c7: from remote pad 0x1000035 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Link 0x020000dd: from remote pad 0x1000036 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Link 0x020000f3: from remote pad 0x1000037 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Link 0x02000109: from remote pad 0x1000038 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Link 0x0200011f: from remote pad 0x1000039 of entity ‘rockchip-mipi-csi2’ (Unknown V4L2 Sub-Device): Data
Priority: 2
Format Video Capture Multiplanar:
Width/Height : 3840/2160
Pixel Format : ‘GB10’ (10-bit Bayer GBGB/RGRG)
Field : None
Number of planes : 1
Flags :
Colorspace : Default
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Default
Plane 0 :
Bytes per Line : 4864
Size Image : 10506240
Selection Video Capture: crop, Left 12, Top 16, Width 3840, Height 2160, Flags:
Selection Video Capture: crop_bounds, Left 12, Top 16, Width 3840, Height 2160, Flags:
Selection Video Output: crop, Left 12, Top 16, Width 3840, Height 2160, Flags:
Selection Video Output: crop_bounds, Left 12, Top 16, Width 3840, Height 2160, Flags:
— /dev/video\* nodes —
crw-rw---- 1 root video 81, 0 Apr 27 14:48 /dev/video0
crw-rw---- 1 root video 81, 1 Apr 27 14:48 /dev/video1
crw-rw---- 1 root video 81, 10 Apr 27 14:48 /dev/video10
crw-rw---- 1 root video 81, 11 Apr 27 14:48 /dev/video11
crw-rw---- 1 root video 81, 12 Apr 27 14:48 /dev/video12
crw-rw---- 1 root video 81, 13 Apr 27 14:48 /dev/video13
crw-rw---- 1 root video 81, 14 Apr 27 14:48 /dev/video14
crw-rw---- 1 root video 81, 15 Apr 27 14:48 /dev/video15
crw-rw---- 1 root video 81, 16 Apr 27 14:48 /dev/video16
crw-rw---- 1 root video 81, 17 Apr 27 14:48 /dev/video17
crw-rw---- 1 root video 81, 18 Apr 27 14:48 /dev/video18
crw-rw---- 1 root video 81, 19 Apr 27 14:48 /dev/video19
crw-rw---- 1 root video 81, 2 Apr 27 14:48 /dev/video2
crw-rw---- 1 root video 81, 3 Apr 27 14:48 /dev/video3
crw-rw---- 1 root video 81, 4 Apr 27 14:48 /dev/video4
crw-rw---- 1 root video 81, 5 Apr 27 14:48 /dev/video5
crw-rw---- 1 root video 81, 6 Apr 27 14:48 /dev/video6
crw-rw---- 1 root video 81, 7 Apr 27 14:48 /dev/video7
crw-rw---- 1 root video 81, 8 Apr 27 14:48 /dev/video8
crw-rw---- 1 root video 81, 9 Apr 27 14:48 /dev/video9
lrwxrwxrwx 1 root root 7 Apr 27 14:48 /dev/video-camera0 → video11
-rw-rw---- 1 root video 71 Jun 10 00:17 /dev/video-dec0
-rw-rw---- 1 root video 4 Jun 10 00:17 /dev/video-enc0
— /dev/media\* nodes —
crw-rw---- 1 root video 249, 0 Apr 27 14:48 /dev/media0
crw-rw---- 1 root video 249, 1 Apr 27 14:48 /dev/media1
GPU / DISPLAY
— DRM devices —
total 0
drwxr-xr-x 3 root root 140 Apr 27 14:48 .
drwxr-xr-x 17 root root 4120 Jun 10 00:17 ..
drwxr-xr-x 2 root root 120 Apr 27 14:48 by-path
crw-rw---- 1 root video 226, 0 Apr 27 14:48 card0
crw-rw---- 1 root video 226, 1 Apr 27 14:48 card1
crw-rw---- 1 root render 226, 128 Apr 27 14:48 renderD128
crw-rw---- 1 root render 226, 129 Apr 27 14:48 renderD129
— GPU memory (Radxa/RK) —
(not accessible: /sys/class/devfreq/fb000000.gpu/cur_freq)
LOADED KERNEL MODULES
— Loaded modules —
Module Size Used by
tcp_diag 16384 0
inet_diag 20480 1 tcp_diag
snd_seq_dummy 16384 0
snd_hrtimer 16384 1
snd_seq 73728 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
rfcomm 65536 4
cifs 618496 2
cifs_arc4 16384 1 cifs
cifs_md4 16384 1 cifs
algif_hash 16384 1
algif_skcipher 16384 1
af_alg 24576 6 algif_hash,algif_skcipher
bnep 24576 2
aic8800_fdrv 532480 0
aic_btusb 36864 0
bluetooth 643072 32 aic_btusb,bnep,rfcomm
zram 28672 2
zsmalloc 24576 1 zram
vfat 20480 2
fat 65536 1 vfat
binfmt_misc 24576 1
pwm_fan 20480 0
snd_soc_es8316 40960 1
snd_soc_rockchip_hdmi 20480 0
aic_load_fw 65536 1 aic8800_fdrv
snd_soc_rockchip_multicodecs 28672 0
cpufreq_dt 20480 0
rockchip_cpufreq 24576 1 cpufreq_dt
ledtrig_netdev 16384 0
ledtrig_timer 16384 0
ledtrig_pattern 16384 0
ledtrig_heartbeat 16384 0
ledtrig_default_on 16384 0
fuse 114688 1
dm_mod 106496 0
ip_tables 28672 0
sdhci_of_dwcmshc 24576 0
dw_hdmi_qp_i2s_audio 16384 0
dw_hdmi_qp_cec 16384 0
SYSTEMD SERVICES (camera-rig)
— camera-node service status —
● camera-node.service - Camera Array Node
Loaded: loaded (/etc/systemd/system/camera-node.service; enabled; preset: enabled)
Active: active (running) since Wed 2026-06-10 00:17:52 CDT; 9min ago
Docs: https://github.com/redacted/camera-array-rig
Main PID: 889 (camera-node)
Tasks: 2 (limit: 19107)
Memory: 4.6M
CPU: 919ms
CGroup: /system.slice/camera-node.service
└─889 /usr/local/bin/camera-node --config /home/radxa/camera-array-rig/node.toml --controller cam001:7000 --heartbeat-interval-ms 1000
— camera-controller service status —
● camera-controller.service - Camera Array Controller
Loaded: loaded (/etc/systemd/system/camera-controller.service; enabled; preset: enabled)
Main PID: 888 (camera-controll)
Tasks: 3 (limit: 19107)
Memory: 2.2M
CPU: 2.114s
CGroup: /system.slice/camera-controller.service
└─888 /usr/local/bin/camera-controller --id controller --bind 0.0.0.0:7000 --heartbeat-timeout-secs 10 --capture-timeout-secs 10
— All failed units —
UNIT LOAD ACTIVE SUB DESCRIPTION
0 loaded units listed.
TIME SYNCHRONISATION
— Current date/time —
Wed Jun 10 05:27:46 AM UTC 2026
— Hardware clock —
— timedatectl —
Timezone=US/Central
LocalRTC=no
CanNTP=yes
NTP=yes
NTPSynchronized=yes
TimeUSec=Wed 2026-06-10 00:27:47 CDT
FIRMWARE & BOOTLOADER
— Device-tree model —
Radxa ROCK 5C
— DTB compatible —
radxa,rock-5c
rockchip,rk3588
KERNEL LOG (last 100 lines, errors/warnings highlighted)
– No entries –
END OF REPORT — 2026-06-10T05:27:47Z
