@radxa radxa老师你们好!启动时触摸屏功能不能使用,重新插拔typec线缆就可以正常使用了,查看了启动日志,发现报错:[ 0.463549][ T1] sunxi:dwc3_sunxi_plat-12.usbc2:[ERR]: couldn’t get drvvbus supply
[ 0.554286][ T1] husb311 failed to find usb power
[ 0.570982][ T1] husb311 14-004e: fail to register tcpci port, -517
[ 2.837010][ T114] husb311 failed to find usb power
是不是husb311供电没有打开,USB0-DRVVBUS该引脚没有使能,下面是启动时的串口信息;
请帮忙分析解答,非常感谢!
[11.331][mmc]: mmc exit start
[11.351][mmc]: mmc 2 exit ok
NOTICE: [SCP] :wait arisc ready…
NOTICE: [SCP] :arisc version: [d463b9da43dc50320f21ba51c6c51afe2db20d83]
NOTICE: [SCP] :arisc startup ready
NOTICE: [SCP] :arisc startup notify message feedback
NOTICE: [SCP] :sunxi-arisc driver is starting
NOTICE: BL3-1: Next image address = 0x40200000
NOTICE: BL3-1: Next image spsr = 0x3c5
[ 0.000000][ T0] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 0.000000][ T0] Linux version 5.15.147-16-a733 (vscode@cb2094f488a8) (aarch64-linux-gnu-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #16 SMP PREEMPT Fri Mar 2
0 10:12:03 UTC 2026
[ 0.000000][ T0] random: crng init done
[ 0.000000][ T0] Machine model: sun60iw2
[ 0.000000][ T0] printk: bootconsole [earlycon0] enabled
[ 0.000000][ T0] AW BSP version: d50167173c, 2026-03-20 10:11:17, RadxaOS SDK
[ 0.077281][ T1] iommu_master csi_iommu: attach fail:-517
[ 0.077340][ T1] sunxi-iommu-v2 3900000.iommu: master probe failed with -517
[ 0.211792][ T1] sunxi:ccu_ddr:[ERR]: dram_clk:2400
[ 0.211805][ T1] sunxi:ccu_ddr:[ERR]: dram_div:0x170b0703
[ 0.212055][ T1] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[ 0.212059][ T1] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[ 0.212108][ T1] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[ 0.212111][ T1] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[ 0.305765][ T1] sun60iw2-pinctrl 2000000.pinctrl: pin PC6 already requested by 4022000.sdmmc; cannot claim for 4023000.sdmmc
[ 0.318741][ T1] sun60iw2-pinctrl 2000000.pinctrl: pin-70 (4023000.sdmmc) status -22
[ 0.327712][ T1] sun60iw2-pinctrl 2000000.pinctrl: could not request pin 70 (PC6) from group PC6 on device 2000000.pinctrl
[ 0.340548][ T1] sunxi-mmc 4023000.sdmmc: Error applying setting, reverse things back
[ 0.399779][ T1] sunxi:sunxi_sidefuse init success!
[ 0.405574][ T1] sunxi:sunxi_smcdrm config service not available: FFFFFFFF
[ 0.406354][ T102] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 0.414357][ T102] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 0.414360][ T102] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 0.414362][ T102] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 0.478034][ T102] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: sdc2 :the host don’t support tuning in kernel
[ 0.492558][ C0] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 18, RD DCE !!
[ 0.502173][ T108] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: retry:stop
[ 0.509837][ T108] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: retry:stop recover
[ 0.518135][ T108] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: send manual stop command failed 100
[ 0.528564][ C0] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 18, RD DCE !!
[ 0.538181][ T108] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: retry:stop
[ 0.545879][ T108] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: retry:stop recover
[ 0.554193][ T108] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: send manual stop command failed 100
[ 0.584108][ T1] sunxi:axp8191_temp_ctrl:[ERR]: axp8191-temp-ctrl device is not configed
[ 0.888339][ T104] sunxi-ufs-pltfm 4520000.ufs: link startup failed 1
[ 0.895795][ T104] sunxi-ufs-pltfm 4520000.ufs: UFS Host state=0
[ 0.902843][ T104] sunxi-ufs-pltfm 4520000.ufs: outstanding reqs=0x0 tasks=0x0
[ 0.911187][ T104] sunxi-ufs-pltfm 4520000.ufs: saved_err=0x0, saved_uic_err=0x0
[ 0.919722][ T104] sunxi-ufs-pltfm 4520000.ufs: Device power mode=1, UIC link state=0
[ 0.928744][ T104] sunxi-ufs-pltfm 4520000.ufs: PM in progress=0, sys. suspended=0
[ 0.937471][ T104] sunxi-ufs-pltfm 4520000.ufs: Auto BKOPS=0, Host self-block=0
[ 0.947669][ T104] sunxi-ufs-pltfm 4520000.ufs: Clk gate=1
[ 0.953955][ T104] sunxi-ufs-pltfm 4520000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[ 0.964330][ T104] sunxi-ufs-pltfm 4520000.ufs: last intr at 885186 us, last intr status=0x404
[ 0.974127][ T104] sunxi-ufs-pltfm 4520000.ufs: error handling flags=0x0, req. abort count=0
[ 0.983740][ T104] sunxi-ufs-pltfm 4520000.ufs: hba->ufs_version=0x300, Host capabilities=0x11870f1f, caps=0x0
[ 0.996244][ T104] sunxi-ufs-pltfm 4520000.ufs: quirks=0x0, dev. quirks=0x0
[ 1.004173][ T104] host_regs: 00000000: 11870f1f 00000000 00000300 00000000
[ 1.012103][ T104] host_regs: 00000010: 00000000 00000926 00000000 00000000
[ 1.020094][ T104] host_regs: 00000020: 00000000 e0000470 00000000 00000000
[ 1.028080][ T104] host_regs: 00000030: 00000008 00000001 00000000 00000000
[ 1.036053][ T104] host_regs: 00000040: 00000000 00000000 00000000 00000000
[ 1.044023][ T104] host_regs: 00000050: 00000000 00000000 00000000 00000000
[ 1.051991][ T104] host_regs: 00000060: 00000000 00000000 00000000 00000000
[ 1.059961][ T104] host_regs: 00000070: 00000000 00000000 00000000 00000000
[ 1.069867][ T104] host_regs: 00000080: 00000000 00000000 00000000 00000000
[ 1.077770][ T104] host_regs: 00000090: 00000000 00000000 00000000 00000000
[ 1.085673][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of pa_err
[ 1.092792][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of dl_err
[ 1.099913][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of nl_err
[ 1.107032][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of tl_err
[ 1.114155][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of dme_err
[ 1.121373][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of auto_hibern8_err
[ 1.129480][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of fatal_err
[ 1.136892][ T104] sunxi-ufs-pltfm 4520000.ufs: link_startup_fail[0] = 0x1 at 886518 us
[ 1.145965][ T104] sunxi-ufs-pltfm 4520000.ufs: link_startup_fail: total cnt=1
[ 1.154157][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of resume_fail
[ 1.161767][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of suspend_fail
[ 1.169471][ T104] sunxi-ufs-pltfm 4520000.ufs: dev_reset[0] = 0x0 at 392999 us
[ 1.177762][ T104] sunxi-ufs-pltfm 4520000.ufs: dev_reset: total cnt=1
[ 1.185173][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of host_reset
[ 1.192685][ T104] sunxi-ufs-pltfm 4520000.ufs: No record of task_abort
[ 2.795188][ T114] sunxi:pcie-rc-6000000.pcie:[ERR]: Speed change timeout
[ OK ] Finished Tell Plymouth To Write Out Runtime Data.
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Finished Flush Journal to Persistent Storage.
Starting **Create Volatile Files and Directories**...
[ OK ] Started Rule-based Manager for Device Events and Files.
Starting **Show Plymouth Boot Screen**...
[ OK ] Reached target Hardware activated USB gadget.
[ OK ] Finished Create Volatile Files and Directories.
[ OK ] Started Entropy Daemon based on the HAVEGE algorithm.
Starting **Network Name Resolution**...
Starting **Network Time Synchronization**...
Starting **Update UTMP about System Boot/Shutdown**...
[ OK ] Started Show Plymouth Boot Screen.
[ OK ] Started Forward Password R…s to Plymouth Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Finished Update UTMP about System Boot/Shutdown.
[ OK ] Found device /dev/ttyAS0.
[ OK ] Started Network Name Resolution.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Reached target System Initialization.
[ OK ] Started CUPS Scheduler.
[ OK ] Started local-apt-repository.path.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Paths.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Refresh fwupd metadata regularly.
[ OK ] Started Daily man-db regeneration.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on CUPS Scheduler.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting **Accounts Service**...
Starting **Avahi mDNS/DNS-SD Stack**...
[ 5.141599][ T281] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dai_link_of failed
[ OK ] Started D-Bus System Message Bus.
[ 5.183752][ T114] debugfs: Directory ‘2535000.i2s3_plat’ with parent ‘allwinner-edp’ already present!
Starting **Network Manager**...
Starting **Remove Stale Onli…t4 Metadata Check Snapshots**...
[ 5.380721][ T287] sunxi:vin:[ERR]: failed to get vipp16 IRQ resource
[ OK ] Started 5.392797][ T287] sunxi:vin:[ERR]: failed to get vipp17 IRQ resource
1;39mirqbalance daemon.
Starting **Initialize hardware monitoring sensors**...
[ 5.444721][ T287] sunxi:vin:[ERR]: fetch vind_mclkpin_vol from device_tree failed
[ 5.457851][ T287] sunxi:vin:[ERR]: vin_pinpower_get_set: set vind_mclkpin error, fail to set regulator voltage!
[ OK ] Started rsetup configuration service.
Starting **RealtimeKit Scheduling Policy Service**...
Starting **User Login Management**...
Starting **Disk Manager**...
Starting **Daemon for power management**...
Starting **WPA supplicant**...
Starting **Linux zramswap setup**...
[ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
[ OK ] Finished Initialize hardware monitoring sensors.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Network Manager.
[ OK ] Started RealtimeKit Scheduling Policy Service.
[ OK ] Started WPA supplicant.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Reached target Network.
[ OK ] Reached target Radxa USB OTG services.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting **CUPS Scheduler**...
Starting **Authorization Manager**...
Starting **OpenBSD Secure Shell server**...
Starting **File System Check…/dev/disk/by-uuid/14D5-A56D**...
Starting **Hostname Service**...
Starting **Permit User Sessions**...
[ OK ] Started User Login Management.
[ OK ] Finished Linux zramswap setup.
[ OK ] Finished Permit User Sessions.
[ OK ] Finished File System Check…n /dev/disk/by-uuid/14D5-A56D.
[ OK ] Started Authorization Manager.
[ OK ] Started Accounts Service.
Mounting **/config**...
Starting **Save/Restore Sound Card State**...
Starting **Hold until boot process finishes up**...
Starting **Terminate Plymouth Boot Screen**...
[ OK ] Started Simple Desktop Display Manager.
Starting **File System Check…/dev/disk/by-uuid/14D5-EF54**...
[ OK ] Started File System Check Daemon to report status.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Hostname Service.
[ 6.919880][ T136] sunxi:sunxidrm:[ERR]: [EDP_ERR]: edp wait aux reply timeout!
