How to wake Rock 2F?
I have the same question as this one about Rock 2F, with additional caveat that it doesn’t have a power button. Is there any way to wake it from suspend?
you can try to wake it by usb key board.
Waking by keyboard does not work. The only way to wake it that I found, if it ever goes to sleep, is to do a hard reset.
Bumping this. Please test waking from keyboard
Sorry, I just asked, USB wakeup is not supported at the moment.
So how to wake this board?
Bump, still this is an issue
Bump.
If there’s no way to wake this board, please just write it, now we just don’t know. Sleep support must then be disabled in the kernel (if that’s how you do this).
Here are the results of the USB suspend and wakeup test I performed on the ROCK 2F using the R3 image:
# echo mem > /sys/power/state
INFO: BL31: v2.3():v2.3-912-gfe961b77f:derrick.huang, fwver: v1.20
INFO: enter: cfg=0x1, sleeptimes:7
INFO: armpd
INFO: PWM_REGULATORS: 0x3
INFO: sleep_pin: 0x0 0x0
INFO: GPIO POWER INFO:
INFO: not config
INFO: GPIO0_INTEN: 0xffff 0xffff 0xffff 0xffff 0x0 0xffffffc0
INFO: GPIO1_INTEN: 0xffff 0xffff 0xffff 0xffff 0x0 0xa00dfff2
INFO: GPIO2_INTEN: 0xffff 0xffff 0xffff 0xffff 0x0 0xffffffe0
INFO: GPIO3_INTEN: 0xffff 0xffff 0xffff 0xffff 0x0 0xffffffff
INFO: GPIO4_INTEN: 0xffff 0xffff 0xffff 0xffff 0x0 0xff6fbfe0
INFO: IRQ_EN: 63
INFO: IRQ_EN: 72
INFO: IRQ_EN: 110
INFO: IRQ_EN: 108
INFO: IRQ_EN: 107
INFO: IRQ_EN: 105
INFO: IRQ_EN: 103
INFO: IRQ_EN: 135
INFO: IRQ_EN: 187
012INFO: pd_st=0x0 idle_st=0x0
3abcde45678INFO: PMU_PWR_CON(0x1) PMU_CRU_PWR_CON(0x1d0 0xe8) PMU_WAKEUP_INT_CON(0x411)
PMU_BUS_IDLE_ST(0x10) PMU_BUS_IDLE_ACK(0x10) PMU_PWR_GATE_ST(0x1)
PMU_BUS_IDLE_CON(0x1ef) PMU_PWR_GATE_CON(0x0) PMU_VOL_GATE_CON(0x1)
PMU_DDR_PWR_CON(0x3) PMU_DDR_PWR_SFTCON(0x0)
PMU_PLLPD_CON(0x1f)
PMU_SCU_PWR_CON(0xaf) PMU_CLUSTER_IDLE_CON(0x2)
SINFO: wake up status: 0x400
INFO: the wake up information:
INFO: USBDEV detect wakeup
a6543edcba2INFO: pd_st=0x0 idle_st=0x0
10INFO: IRQ_EN: 63
INFO: IRQ_EN: 72
INFO: IRQ_EN: 110
INFO: IRQ_EN: 108
INFO: IRQ_EN: 107
INFO: IRQ_EN: 105
INFO: IRQ_EN: 103
INFO: IRQ_EN: 135
INFO: IRQ_EN: 187
INFO: IRQ_PED: 182
From the current results, the ROCK 2F does support USB suspend and wakeup. You can try testing it using the R3 image.
Image link:
https://github.com/radxa-build/radxa-rk3528/releases/download/rsdk-r3/radxa-rk3528_bookworm_kde_r3.output_512.img.xz
Additional note: the USB suspend and wakeup test mentioned above was performed using a keyboard device.
Thank you, must be a problem with my image then
