11142
May 31, 2023, 1:57am
1
I connected 5V(PIN4), D-(PIN16), D+(PIN18), GND(PIN20) to the female socket, and inserted the mouse on the female socket, but the OS did not respond
img:https://github.com/radxa/rock-pi-images-released/releases/download/v20210824/rockpie_debian_buster_server_arm64_20210824_0255-gpt.img.gz
If I use the usb3.0 port to detect the mouse, it can be captured. How to use usb2.0(on the 40-pin header) and what settings do I need?
feng
May 31, 2023, 3:25am
2
I connected a TYEPA female port with a lead wire, and then connected it to a HUB. Both the mouse and the U disk can be used without any other special operations.The mirror of this wiki official website I use: https://github.com/radxa/rock-pi-images-released/releases/download/v20210824/rockpie_debian_buster_server_arm64_20210824_0255-gpt.img.gz
You can try this mirror image, or swap D+ and D- to try.
11142
May 31, 2023, 6:24am
3
I use the same img as you, but it doesn’t work,
My ROCK PI E is v1.2, which version is your ROCK PI E?
Is it convenient to upload your ROCK PI E and HUB connection photos?
feng
June 2, 2023, 2:02am
4
My ROCK PI E is v1.21, the following is the picture I tested, and it can be used normally with a U disk inserted on it.
feng
June 2, 2023, 2:34am
5
Do you have a skype account? If it is convenient to provide it, we can discuss it on skype, and the efficiency will be higher.
11142
June 2, 2023, 4:01am
6
hi,my skype :bxbrd09
waiting for you to add me
thanks
