How to use bluetooth in Android container in docker
how to use bluetooth in Android container in docker with ax210
this is my command
docker run -itd --privileged
–pull always
-v “$(pwd)”/Android:/data
-v /dev:/dev
-v /run/dbus:/run/dbus
-v /var/run/dbus:/var/run/dbus
–mount=type=bind,source=/dev/mali0,destination=/dev/mali0
-p 5555:5555
chisbread/rk3588-gaming:redroid-firefly
androidboot.redroid_width=1080
androidboot.redroid_height=1920
androidboot.redroid_dpi=480
androidboot.redroid_fps=30
androidboot.redroid_gpu_mode=host
my Bluetooth device
Bus 001 Device 004: ID 8087:0032 Intel Corp. AX210 Bluetooth
In which OS just to… understand where you are trying to run it ?
armbian ubuntu22
Have you got this working in the build we are messing with?
what is you mean? my android container is working, but Bluetooth can not be use
感谢老哥的docker镜像…
不是我提取的镜像,我只是一个收集者
