I’m a newbie, I use Emmc USB Reader + 48g Emmc + wifi A8, after the rock5b is started, only the green light is always on, and there is no sound, I don’t have display and network cable, only wifi username and password, how can I configure my rock5b to automatically start with my wifi username and password? (Can I use the Raspberry Pi ubuntu image? It can edit the configuration file to configure the default wifi username and password before starting), thanks
Hi luna, please keep in mind that the rock5b is more or less a development platform, maybe you need a monitor, keybaord and network to have a inital setup. The raspberry images are not usable, you need a rock5b compatible image.
I’m not aware that this images has the same configurable options for ssh and wifi. Maybe someone else knows that.
I would recommend to use a monitor and keyboard to do the inital setup.
Best regards
n0x
The rock 5b doesn’t have a wifi module(unless you added one yourself). Therefore you will need either a network cable or a mobile phone with USB cable. For the latter, do the following:
Add to /etc/network/interfaces on your SD card
Auto usb0
iface usb0 inet dhcp
Attach phone via USB to rock 5 and setup USB tethering in settings-network(android only)
Nvm I just read you have the wifi module. In that case add the wifi config in /etc/network/interfaces
It should be along the lines of:
iface wlan0 inet dhcp
wpa-ssid your network name
wpa-psk yourwifipassword
The name of the wifi interface might be different, I would ask someone who does have that wifi module to confirm that it’s named wlan0 and doesn’t have a node-specific name or is named wlo1 altogether
