How to set up KGDB on Armbian
Hello, I’m using Armbian with kernel 6.1.57 on a Radxa Zero board. I want to configure the target board to allow me to debug remotely via KGDB on serial port.
I have enabled KGDB via the following kernel config switches:
CONFIG_FRAME_POINTER=y
CONFIG_KGDB=y
CONFIG_KGDB_SERIAL_CONSOLE=y
CONFIG_GDB_SCRIPTS=y
I also added extraargs=kgdboc=ttyAML0,115200 to /boot/armbianEnv.txt
However, the kernel now puts this into the kernel log when the system is booted:
[ 0.000000] Unknown kernel command line parameters “splash ubootpart=1fc53e99-01 kgdboc=ttyAML0,115200 cgroup_enable=memory”, will be passed to user space.
So, what is the proper way to enable KGDB/GDB remote debugging over a serial port in Armbian?
Thanks.
