I downloaded the file, flash it on the sd card, and booted it, but it comes out like the attached picture, and only loopback comes out when I enter the nmcli command.
When the Wi-Fi was working normally after rebooting yesterday, wlan0 was also released.
While working on emmc, did you touch the board yourself and damage the board?
Or I think the power of this power adapter I’m using may be too strong.
It says 5v3a output.
Now I’m trying to use the latest version of ubuntu.
Used balenaEtcher to flash to EMMC that i prepared
booted right away…not sure about the power …mine is connected directly to my laptop’s usb port or i have an external powerbank that i connect…i ididnt have issue with power…
Can you use radxa-zero-erase-emmc before the udisk loader ? it should get rid of everything
and what about the drivers for usb ? maybe installing them again might work ?
Before raising android-bootloader.bin, it was possible to enter usb mode, and the radxa-zero-erase-emmc.bin file still seems to be operating normally.
Through the zadig program, the driver worked normally in maskrom mode, and when it says usb download gadget, something seems to be wrong with the driver.
By the way, is this problem related to the wifi problem when booting with an sd card?
Im not sure. I hope someone with more knowledge will give an answer…I had some other problems when i first got the zero. and it is frustrating for sure.
I did not have any wifi problem with my 64gb version of zero.
But i got recently 128gb verion and im having wifi problems…still working on it and trying to understand.
Because both boards are 4gb, which means they both should have same module.
2GB or 4GB memory, it comes with **AP6256** module
512MB or 1GB memory, it comes with **AP6212** module
No problem, i wish i could help further. I will keep an eye on this topic for sure.
I dont think board would be broken that easily. because form my experience it is very durable:) - i do use it a bit rough to be honest.
