I would like to use the Radxa Zero as a USB serial device. It would be connected via a single USB A to USB C cable to a host. On the host it should advertise itself as a USB serial device while its being powered via the same cable.
Is this possible?
In the past I was doing this on the Pi Zero (https://www.tal.org/tutorials/raspberry-pi-zero-usb-serial-console) and wanted to check if I can achieve the same with the Radxa Zero.
Thanks for your support on this question and have a good weekend.
( Maybe this is another topic )
I am asking if USB3 or USB2 can be emulated as RNDIS client? ( or any interface capable of running off USB hub )? looking forward to use this to build a cluster
Hey,
I have the same setup - did you figure the RNDIS setting out?
My usual config is RPi4 running RNDIS on Mac and PC just fine.
I hope there will be a config for that soon.
