New post from a newbie!
I have searched for an answer but I am not finding any information so please forgive me if this question is already answered.
How do I enable the 2 pin header on the Rock Pi4c for fan connection?
The specification says it can be used with PWM, but I can only see how to enable PWM on the 40 pin connector. I will be using the 40 pin header so I want to transfer the fan to the 2 pin header.
I have seen posts on pwm use on other boards. There are two disabled rk3399-pwm*dto files in /boot. You might start there. And I think in rock 5b boards either in this forum or discord , there are instructions on implementing a script and “pwm curve” that may apply to this as well. I don’t use it, i just connect to 5v / grnd pins on gpio and let it run full on. The NAS, 3d printer, work laptop dans, tv, music or other usually drown out that annoying fan noise. LOL
Finally I have a solution after some research, hints from other models and some experimentation.
I have two small fans connected to the 2 pin header and I can control by writing to
/sys/class/thermal/cooling_device2/cur_state
0 off, 1 single fan runs, 2 both fans run quiet, 3 both fans full speed
Writing with sudo nano worked but the change was not persistent and reset after boot.
Tried using echo in a bash script to run at startup but hit permissions errors.
Solution was adding a udev rule:
/etc/udev/rules.d/02-radxa-fan.rules
ACTION==“add|change”, KERNEL==“cooling_device2”, SUBSYSTEM==“thermal”, ATTR{cur_state}=“3”
The fans now start on boot and stop on exit
Some useful commands that may be obvious to others but were not to me…
Test rule: sudo udevadm test /sys/class/thermal/cooling_device2
Start rules: sudo udevadm trigger or sudo udevadm control --reload
Check attributes: udevadm info -a /sys/class/thermal/cooling_device2
