How to enable dpu&gpu on Orion O6(ubuntu 24.10)
  1. Install Ubuntu
    download https://cdimage.ubuntu.com/ubuntu/releases/oracular/release/ubuntu-24.10-desktop-arm64.iso and install.
    After Install, ubuntu use cpu render and uefi display.
    Step 1:Enable DPU,use cpu render and dpu display.
    Step 2:Enale GPU,use gpu render and dpu display.
  2. Enable DPU
  • Install kernel deb package on system
    dpkg -i linux-headers-6.1.44-cix-build-generic_6.1.44-cix-build-generic-2_arm64
    dpkg -i linux-image-6.1.44-cix-build-generic_6.1.44-cix-build-generic-2_arm64
    dpkg -i linux-libc-dev_6.1.44-cix-build-generic-2_arm64
    cp /usr/lib/linux-image-6.1.44-cix-build-generic/cix/sky1-evb.dtb /boot/
    %E5%9B%BE%E7%89%871
  • Modify grub
    Change/boot/grub/grub.cfg to the following content:
    root@gzj-System-Product-Name:/# cat /boot/grub/grub.cfg
    set debug=loader,mm
    set term=vt100
    set default=0
    set timeout=5
menuentry ‘0 Orion O6 devicetree’ {
devicetree /boot/sky1-xxxx.dtb
linux /boot/vmlinuz-6.1.44-cix-build-generic
console=ttyAMA2,115200
efi=noruntime
earlycon=pl011,0x040d0000
arm-smmu-v3.disable_bypass=0
acpi=off
loglevel=4
root=/dev/nvme0n1p2 noresume rootwait rw
  • Verify
    reboot system
    If multiple resolutions can be seen through the settings ->display, it can be considered that dpu enable is successful
    lsmod command can see that linlon_dp.ko is loaded and also confirm that dpu enable is successful
    %E5%9B%BE%E7%89%872
  1. Enable GPU
  • install gpu kmd: dpkg -i cix-gpu-driver_1.0.0_arm64.deb
  • install cix-firmware: dpkg -i cix-firmware_1.0.0_arm64.deb
  • install cix-env
    rm -rf /bin/sh
    ln -sf /bin/bash /bin/sh
    dpkg -i --force-overwrite cix-env_1.0.0_arm64.deb
  • install cix-go
    tar -xvf cix-go-1.0.0.tar.gz
    cd cix-go
    ./install.sh
  • reboot system
  • Verify: Confirm that the pid of gnome_shell is in the/sys/kernel/debug/mli0/ctx directory
    %E5%9B%BE%E7%89%873
I am looking forward to activate the GPU on Debian 12 so I guess your steps will likely work.
However I searched on the gitlab for any .deb without success. Do I need to compile anything from source or are those binaries available somewhere else ?
EDIT : I think I found it here
Eventually did not manage to install drivers on Debian 12 native.
What I tried :
  • Try to apt install available packages from radxa github repository. (FAIL)
  • dpkg-repack a lot of the cix packages (including kernel image) from the live debian. Then dpkg -i *.deb on a native debian. Either it fails or if it passes, GUI won’t start at boot. (FAIL)
  • Compile kernel locally won’t help either.
So far, I could not reach the state of a native Debian with working drivers, let it be GPU or Wlan / BT.
Hi, could you share the ubuntu 24.10 arm64 image, I cannot download the iso image, it shows Not Found
The requested URL was not found on this server.
Have try 25.10/25.04, need to set SPCR enable, then the Ubuntu OS could be installed, otherwise will have kernel panic and install stop.
