Guys, do you have any guide to create wifi access point on radxa zero ?
Does wifi chipset supporting the ac and client mode simultaneously?
Thanks.
It seems like the wifi chipset doesn’t supporting the access point and the client mode at the same time.
Here is an answer from radxa team.
Did you manage to install the Access Point on the Zero?
I’m currently trying this tutorial:
https://wiki.radxa.com/Rock/Wireless/AP_mode_manually
But i get errors in this section:
Build wifi driver
root@radxa:/tmp/driver/rtl8723A_Wi…3.3_beta# make
also the tutorial is poorly written because file locations change without it being mentioned in the instructions.
I’ve created a new topic with my progress: Problems creating an Access Point on Radxa Zero
