Hi there,
I installed the SPI driver following steps on
After reboot could see the SPI initialized:
dmesg | grep spi
[ 0.013052] ACPI: SSDT ACPI table found in initrd [kernel/firmware/acpi/spidev1.1.aml][0xb7]
[ 0.013058] ACPI: SSDT ACPI table found in initrd [kernel/firmware/acpi/spidev1.0.aml][0xb7]
[ 2.916464] spidev spi-SPT0001:00: do not use this driver in production systems!
Connected MOSI and MISO together. And then used spidev_test tool to check the spidev1.0 interface:
sudo ./spidev_test -D /dev/spidev1.0 -v
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 kHz)
TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D |......@.........................|
RX | FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF |................................|
Well, for some reasons the data sent is not received on the other end. What did I miss?
Thanks
