How to boot linux from microSD?
Hi
After burning “radxa-zero-debian-buster-xfce4-arm64-20211227-1055-mbr.img” on MicroSD card
and trying to boot it, - there was the same Android.
So, following Can NOT boot from SD (Debian installed) and https://wiki.radxa.com/Zero/install/eMMC_erase, - I’ve erased emmc:
# sudo boot-g12.py rz-fastboot-loader.bin
Firmware Version :
ROM: 3.2 Stage: 0.0
Need Password: 0 Password OK: 1
Writing rz-fastboot-loader.bin at 0xfffa0000...
[DONE]
Running at 0xfffa0000...
[DONE]
AMLC dataSize=16384, offset=65536, seq=0...
[DONE]
AMLC dataSize=49152, offset=393216, seq=1...
[DONE]
AMLC dataSize=16384, offset=229376, seq=2...
[DONE]
AMLC dataSize=49152, offset=245760, seq=3...
[DONE]
AMLC dataSize=49152, offset=294912, seq=4...
[DONE]
AMLC dataSize=16384, offset=65536, seq=5...
[DONE]
AMLC dataSize=1406320, offset=81920, seq=6...
[DONE]
[BL2 END]
# fastboot erase 0
Erasing '0'                                        OKAY [  8.441s]
Finished. Total time: 8.477s
# fastboot reboot
Rebooting                                          OKAY [  0.000s]
Finished. Total time: 0.101s
And now there is no Android, and yet it also doesn’t boot any Linux from MicroSD.
Is there something missed? Any suggestions?
(Serial console output is below)
U-Boot 2015.01-g7386aaa (Aug 22 2021 - 11:36:23)
DRAM:  3.8 GiB
Relocation Offset is: d6e8e000
spi_post_bind(spifc): req_seq = 0
register usb cfg[0][1] = 00000000d7f4b628
NAND:  MMC:   aml_priv->desc_buf = 0x00000000d3e7ea70
aml_priv->desc_buf = 0x00000000d3e80db0
SDIO Port B: 0, SDIO Port C: 1
co-phase 0x3, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
co-phase 0x3, tx-dly 0, clock 40000000
aml_sd_retry_refix[983]:delay = 0x0,gadjust =0x182000
[mmc_startup] mmc refix success
[mmc_init] mmc init success
start dts,buffer=00000000d3e83620,dt_addr=00000000d3e83620
check_valid_dts: FDT_ERR_BADMAGIC
get_partition_from_dts() 91: ret -9
get_partition_from_dts() 94: ret -9
get_ptbl_from_dtb()-272: get partition table from dts faild
mmc_device_init()-1254: get partition table from dtb failed
get_ptbl_rsv()-494: magic faild MPT,
mmc_device_init()-1281: dtb&rsv are not exist, no LPT source
get partition info failed !!
Using default environment
In:    serial
Out:   serial
Err:   serial
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-3477: calc 0, store 0
update_dtb_info()-3585: cpy 1 is not valid
update_dtb_info()-3585: cpy 0 is not valid
dtb_read()-3694: total valid 0
emmc - EMMC sub system
Usage:
emmc dtb_read addr size
emmc dtb_write addr size
emmc erase dtb
emmc erase key
emmc fastboot_read addr size
emmc fastboot_write addr size
[KM]Error:f[keymanage_dts_parse]L307:not a fdt at 0x0000000001000000
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: vpu_power_on
vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100)
vpu: vpu_module_init_config
vpp: vpp_init
vpp: vpp osd2 matrix rgb2yuv..............
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
aml_config_dtb 667
aml_config_dtb 697
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Net:   No ethernet found.
CONFIG_AVB2: null
Start read misc partition datas!
Cannot find dev.
amlmmc cmd <NULL> failed
store - STORE sub-system
Usage:
store init flag
store read name addr off|partition size
    read 'size' bytes starting at offset 'off'
    to/from memory address 'addr', skipping bad blocks.
store write name addr off|partition size
    write 'size' bytes starting at offset 'off'
store rom_write add off size.
        write uboot to the boot device
store erase boot/data:
        erase the area which is uboot or data
store erase partition <partition_name>:
        erase the area which partition in u-boot
store erase dtb
store erase key
store disprotect key
store rom_protect on/off
store scrub off|partition size
        scrub the area from offset and size
store dtb iread/read/write addr <size>
        read/write dtb, size is optional
store key read/write addr <size>
        read/write key, size is optional
store ddr_parameter read/write addr <size>
        read/write ddr parameter, size is optional
store mbr addr
   update mbr/partition table by dtb
[burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store  read misc 0xd3e7d090  0x0  0x820]
failed to store read misc.
info->magic =
info->version_major = 0
info->version_minor = 0
info->slots[0].priority = 0
info->slots[0].tries_remaining = 0
info->slots[0].successful_boot = 0
info->slots[1].priority = 0
info->slots[1].tries_remaining = 0
info->slots[1].successful_boot = 0
info->crc32 = 0
Magic  is incorrect.
boot-info is invalid. Resetting.
save boot-info
info->magic =
info->version_major = 1
info->slots[0].priority = 15
info->slots[0].tries_remaining = 7
info->slots[1].priority = 14
info->slots[1].tries_remaining = 7
info->crc32 = -1075449479
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_write_ops,L148:cmd [store  write misc 0xd3e7d090  0x0  0x820] failed active slot = 0
wipe_data=successful
wipe_cache=successful
upgrade_step=0
reboot_mode:::: cold_boot
hpd_state=0
edid preferred_mode is <NULL>[0]
hdr mode is 0
dv  mode is ver:0  len: 0
hdr10+ mode is 0
[OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters
[OSD]set initrd_high: 0x3d800000
[OSD]fb_addr for logo: 0x3d800000
[OSD]VPP_OFIFO_SIZE:0xfff01fff
[CANVAS]canvas init
[CANVAS]addr=0x3d800000 width=3840, height=2160
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store  read logo 0x1080000  0x0  0x2000]
Err imgread(L537):Fail to read 0x2000B from part[logo] at offset 0
There is no valid bmp file at the given address
[OSD]osd_hw.free_dst_data: 0,719,0,575
[OSD]osd1_update_disp_freescale_enable
hdmitx: outputmode[576cvbs] is invalid
vpp: Rx hdr_info.hdr_sup_eotf_smpte_st_2084 = 0
gpio: pin GPIOAO_3 (gpio 3) value is 1
Command: bcb uboot-command
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store  read misc 0xd3e7d080  0x0  0x440]
bcb - bcb
Usage:
bcb
This command will run some commands which saved in misc
partition by mark to decide whether execute command!
Command format:
  bcb bcb_mark
Example:
  /dev/block/misc partiton is saved some contents:
  uboot-command
  N/A
  setenv aa 11;setenv bb 22;setenv cc 33;saveenv;
So you can execute command: bcb uboot-command
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
card in
co-phase 0x2, tx-dly 0, clock 400000
co-phase 0x2, tx-dly 0, clock 40000000
aml_sd_retry_refix[983]:delay = 0x0,gadjust =0x2000
init_part() 282: PART_TYPE_DOS
reading boot.ini
** Unable to read file boot.ini **
** No partition table - mmc 1 **
MMC Device 2 not found
** Bad device mmc 2 **
Device: SDIO Port B
Manufacturer ID: 2
OEM: 544d
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.5 GiB
mmc clock: 40000000
Bus Width: 4-bit
reading s905_autoscript
** Unable to read file s905_autoscript **
(Re)start USB...
USB0:   USB3.0 XHCI init start
Register 3000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus 0 for devices... 1 USB Device(s) found
** Bad device usb 0 **
** Bad device usb 1 **
** Bad device usb 2 **
** Bad device usb 3 **
** Unrecognized filesystem type **
pll tsensor avg: 0x1f04, u_efuse: 0x6
temp1: 31
ddr tsensor avg: 0x1f29, u_efuse: 0x8050
temp2: 31
device cool done
CONFIG_SYSTEM_AS_ROOT: systemroot
system_mode: 1
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
info->magic =
info->crc32 = 0
Magic  is incorrect.
save boot-info
info->magic =
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
CONFIG_AVB2: null
active_slot: normal
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store  read boot 0x1080000  0x0  0x100000]
Err imgread(L328):Fail to read 0x100000B from part[boot] at offset 0
InUsbBurn
[MSG]sof
Set Addr 1
Get DT cfg
Get DT cfg
set CFG
You can follow this guide to completely wipe out the residual bootloaders as well. That should allow you to boot from microSD
Thanks, it works
# lsusb | grep Aml
Bus 002 Device 013: ID 1b8e:c003 Amlogic, Inc. GX-CHIP
# boot-g12.py android-bootloader.img
Firmware Version :
ROM: 3.2 Stage: 0.0
Writing android-bootloader.img at 0xfffa0000...
[DONE]
[DONE]
[DONE]
[DONE]
[DONE]
[DONE]
[DONE]
[DONE]
AMLC dataSize=1127792, offset=81920, seq=6...
[DONE]
[BL2 END]
# fastboot devices
AMLG12A-RADXA-ZERO	Android Fastboot
# fastboot flashing unlock
OKAY [  0.036s]
Finished. Total time: 0.036s
# fastboot flashing unlock_critical
OKAY [  0.034s]
Finished. Total time: 0.034s
# fastboot erase bootloader
Erasing 'bootloader'                               OKAY [  0.025s]
Finished. Total time: 0.564s
# fastboot erase bootloader-boot0
Erasing 'bootloader-boot0'                         OKAY [  0.039s]
Finished. Total time: 0.580s
# fastboot erase bootloader-boot1
Erasing 'bootloader-boot1'                         OKAY [  0.032s]
Finished. Total time: 0.573s
and then in console:
[ 12.330074] EXT4-fs (mmcblk1p2): resizing filesystem from 597253 to 3661580 blocks
[ 14.960863] EXT4-fs (mmcblk1p2): resized filesystem to 3661580
Debian GNU/Linux 10 radxa-zero ttyAML0
radxa-zero login: [   16.094871] broken atomic modeset userspace detected, disabling atomic
[  OK  ] Started Resize root filesy…m to fit available disk space.
radxa-zero login: rock
Password: rock
Linux radxa-zero 5.10.69-9-amlogic-g7c418f844e4b #amlogic SMP PREEMPT Sun Dec 12 14:29:18 UTC 2021 aarch64
This is normal. Our official image will resize the root partition to use all space in your storage media.
Yes, thank you again for helping
I would like to continue this thread with how to erase the emmc using boot-g12a.py
lsusb | grep Aml
Bus 001 Device 015: ID 1b8e:c003 Amlogic, Inc. GX-CHIP
[user@user-pc Downloads]$ python --version
Python 3.10.1
[user@user-pc Downloads]$ sudo boot-g12.py rz-fastboot-loader.bin
Firmware Version :
ROM: 3.2 Stage: 0.0
  File "/usr/bin/boot-g12.py", line 35, in <module>
    dev.writeLargeMemory(0xfffa0000, data[0:0x10000], 4096)
  File "/usr/lib/python3.10/site-packages/pyamlboot/pyamlboot.py", line 239, in writeLargeMemory
    self._writeLargeMemory(address+offset, data[offset:offset+writeLength], \
  File "/usr/lib/python3.10/site-packages/pyamlboot/pyamlboot.py", line 220, in _writeLargeMemory
    ep.write(data[offset:offset+blockLength], 1000)
  File "/usr/lib/python3.10/site-packages/usb/core.py", line 408, in write
    return self.device.write(self, data, timeout)
  File "/usr/lib/python3.10/site-packages/usb/core.py", line 989, in write
    return fn(
  File "/usr/lib/python3.10/site-packages/usb/backend/libusb1.py", line 837, in bulk_write
    return self.__write(self.lib.libusb_bulk_transfer,
  File "/usr/lib/python3.10/site-packages/usb/backend/libusb1.py", line 938, in __write
    _check(retval)
  File "/usr/lib/python3.10/site-packages/usb/backend/libusb1.py", line 602, in _check
    raise USBTimeoutError(_strerror(ret), ret, _libusb_errno[ret])
usb.core.USBTimeoutError: [Errno 110] Operation timed out
Does not work on Python 3.10
Host pc is Manjaro Linux x86_64
I thought maybe it will work on Ubuntu as per the wiki but here is the log on ubuntu.
spikerguy@spikerguy:~$ sudo boot-g12.py radxa-zero-erase-emmc.bin
[sudo] password for spikerguy:
Firmware Version :
ROM: 3.2 Stage: 0.0
Writing radxa-zero-erase-emmc.bin at 0xfffa0000...
  File "/usr/local/bin/boot-g12.py", line 35, in <module>
  File "/usr/local/lib/python3.8/dist-packages/pyamlboot/pyamlboot.py", line 239, in writeLargeMemory
  File "/usr/local/lib/python3.8/dist-packages/pyamlboot/pyamlboot.py", line 220, in _writeLargeMemory
  File "/usr/local/lib/python3.8/dist-packages/usb/core.py", line 408, in write
  File "/usr/local/lib/python3.8/dist-packages/usb/core.py", line 989, in write
    return fn(
  File "/usr/local/lib/python3.8/dist-packages/usb/backend/libusb1.py", line 837, in bulk_write
  File "/usr/local/lib/python3.8/dist-packages/usb/backend/libusb1.py", line 938, in __write
    _check(retval)
  File "/usr/local/lib/python3.8/dist-packages/usb/backend/libusb1.py", line 602, in _check
spikerguy@spikerguy:~$ uname -a
Linux spikerguy 5.4.0-90-generic #101-Ubuntu SMP Fri Oct 15 20:00:55 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
spikerguy@spikerguy:~$ python --version
Command 'python' not found, did you mean:
  command 'python3' from deb python3
  command 'python' from deb python-is-python3
spikerguy@spikerguy:~$ python3 --version
Python 3.8.10
spikerguy@spikerguy:~$ lsusb
Bus 001 Device 003: ID 1b8e:c003 Amlogic, Inc. GX-CHIP
Bus 001 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Here is what I got on EndavourOS:
[yuntian@Yuntian ~]$ sudo boot-g12.py ~/Documents/GitHub/fip/radxa-zero/radxa-zero-erase-emmc.bin
Firmware Version :
ROM: 3.2 Stage: 0.0
Writing /home/yuntian/Documents/GitHub/fip/radxa-zero/radxa-zero-erase-emmc.bin at 0xfffa0000...
[DONE]
[DONE]
[DONE]
[DONE]
[DONE]
[DONE]
[DONE]
[DONE]
AMLC dataSize=1324400, offset=81920, seq=6...
[DONE]
[BL2 END]
[yuntian@Yuntian ~]$ sha256sum ~/Documents/GitHub/fip/radxa-zero/radxa-zero-erase-emmc.bin
9fde79fc83665cdeed445c987877a2245719c59ca913fb5d0213560ba8e75ab1  /home/yuntian/Documents/GitHub/fip/radxa-zero/radxa-zero-erase-emmc.bin
[yuntian@Yuntian ~]$ python --version
Python 3.10.2
Then I think it is my emmc thats corrupted which is confirmed when I tried to install Manjaro on eMMC it fails with I/O error.
Yeah I’ll let you know when we have some samples available to replace the board for you.
