My hat use this pin for Datacontrol but it’s not working.
If I set the pin HIGH after an export : echo 1 > /sys/class/gpio/gpio475/value
the value stay still LOW. I’v tested on several zero SBC
The zero documentation says : Pin#22 (GPIOC_7) and Pin#36 (GPIOH_8) are not available in the user space
However, is it possible to expose and change this GPIO by another way? Libmraa for example?
I wonder because I tell myself, why does this GPIO pin exist if we can’t change the value?
I don’t know who wrote that line but if you check the reference manual those 2 pins are open drain (OD), which means they need to have a pull up resistor to work as output, and that was not implemented on our board. I think you can try set them in input mode and check you indeed have access of them from userland. GPIOC_7 is OD3.3V and GPIOH_8 is OD5V, so you should get 0 when connect to GND and 1 when connect to VCC.
