- How do I install mainline u-boot on microSD card?
- Do I just need to configure it for Rock Pi 4, build it, and install it in the partition structure recommended by mainline u-boot? rockchip-bsp seems to insert idbloader and trust.img, too. I wonder mainline u-boot needs those files.
- How do I install mainline u-boot on SPI flash?
How do I install mainline u-boot on Rock Pi 4?
Build mainline u-boot is the same for all arm64 Rockchip soc. You can refer:
Hello Jack,
I want to boot ROCKPI4 with mainline u-boot (do not need linux).
From the given link,
http://opensource.rock-chips.com/wiki_U-Boot
I build the images( idbloader.img,u-boot.itb ) in the mainline u-boot code ( with rock-pi-4-rk3399 configuration).
At the link “http://opensource.rock-chips.com/wiki_Boot_option”,
Under the section " Boot from SD/TF Card" ,the commands to flash the images into sd card is mentioned as below.
dd if=idbloader.img of=sdb seek=64
dd if=u-boot.itb of=sdb seek=16384
dd if=boot.img of=sdb seek=32768
dd if=rootfs.img of=sdb seek=262144
should the sd-card device be formatted to a particular file-system type??
Should we also partition the sd card??
If yes,please mention their details.
Regards,
Adarsh
If you are loading boot image or a script from a file system, then yes. It has to be ext4 or fat.
Hi All,
My Host System Configuration is with Ubuntu Linux -16.04 LTS
Among the below commands:
I tried the first two and they needed modification.
Also, I had to initially prepare my sdhc card with all the mentioned partitions and then
execute the below commands.
dd if=idbloader.img of=/dev/sdb seek=64
dd if=u-boot.itb of=/dev/sdb seek=16384
or
dd if=idbloader.img of=/dev/sdb1
dd if=u-boot.itb of=/dev/sdb2
Regards,
Adarsh
The link to download is down.
Can I get the new one?
