I have a rockpi 4b with twister os armbian installed. I would like to run it headless. I installed x11vnc, but without a monitor plugged in, I only get 800x600. I would prefer 1920x1024.
If I had a raspberry pi, I could modify config.txt and fix it. I am unsure in armbian. I tried modifying boot me (and compiling), and armbianEnv.txt, but it didn’t work.
Any advice?
Hi @splashd, take a look at Xvfb and see if that can provide a connection for your vnc matching your preferred resolution.
Thanks. I tried that, but I cannot get a remote display I can access. Not sure how to map the Xvfb display 1 to the vncserver (which is set to the default desktop display 0).
I really need the ability to set the x11vnc to a useful resolution for a remote desktop experience.
It’s been eons since I used Xvfb for anything but you’re starting it via rc.local or other means with your preferred resolution?
Here’s the overview:
https://www.x.org/releases/X11R7.6/doc/man/man1/Xvfb.1.xhtml
Depending on your x server settings, you may need to also allow access to your client with:
xhost + client_IP
You can check your X log to see if there are any denied connections from your client.
Remote vnc connections can typically specify the alternate display with:
sbc_IP:DISP_#
I haven’t tried x11-vnc, is this the guidance you’re using?
https://wiki.archlinux.org/title/X11vnc
Perhaps worth trying TigerVNC or another daemon?
Depending on what x-app(s) you need to run, you can also forward them over ssh. For instance, connecting with:
ssh -X user@sbc_IP
Will allow you to run xterm or firefox and have them launch on your local system. Depending on your client system, you may need to run a X emulator.
Over WAN connections you may also want to add the -C flag to enable compression.
Here’s to your weekend!
