Help with uboot problem
I’ve begun work integrating the rock 5b into the github flatmax buildroot.rockchip external repo.
You can see the configuration and setup here :
I’m getting problems with uboot. It appears to be having problems loading the boot scrip. Here is the console output :
DDR Version V1.07 20220412
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09 (Jul 11 2022 - 13:57:36)
Trying to boot from MMC2
spl: partition error
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(5ae6932916…) + OK
## Checking uboot 0x00200000 … sha256(5ba7778442…) + OK
## Checking fdt 0x00309e78 … sha256(f054bfeb69…) + OK
## Checking atf-2 0x000f0000 … sha256(c00c7fd75b…) + OK
## Checking atf-3 0xff100000 … sha256(71c3a5841b…) + OK
## Checking atf-4 0xff001000 … sha256(2301cf73be…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 600.621 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-384-g45c8fcb44:derrick.huang
NOTICE:  BL31: Built : 15:14:04, Jun 18 2022
INFO:    ext 32k is not valid
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    system boots from cpu-hwid-0
INFO:    idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO:    dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO:    dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO:    dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO:    dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO:    BL31: Initialising Exception Handling Framework
INFO:    BL31: Initializing runtime services
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (Jul 11 2022 - 13:57:36 +1000)
Model: Radxa ROCK 5B
PreSerial: 2, raw, 0xfeb50000
DRAM:  7.7 GiB
Sysmem: init
Relocation Offset: edb6d000
Relocation fdt: eb9f9b38 - eb9fecc0
CR: M/C/I
Using default environment
no mmc device at slot 1
mmc@fe2c0000: 1 (SD), mmc@fe2e0000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 52Mhz
PartType: EFI
DM: v2
No misc partition
boot mode: None
No resource partition
Failed to load DTB, ret=-19
No find valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
  b0pll 24000 KHz
  b1pll 24000 KHz
  lpll 24000 KHz
  v0pll 24000 KHz
  aupll 24000 KHz
  cpll 1500000 KHz
  gpll 1188000 KHz
  npll 24000 KHz
  ppll 1100000 KHz
  aclk_center_root 702000 KHz
  pclk_center_root 100000 KHz
  hclk_center_root 396000 KHz
  aclk_center_low_root 500000 KHz
  aclk_top_root 750000 KHz
  pclk_top_root 100000 KHz
  aclk_low_top_root 396000 KHz
No misc partition
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot.scr
reading /boot.scr
1113 bytes read in 3 ms (362.3 KiB/s)
## Executing script at 00500000
Unknown command '������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������SCRIPT FAILED: continuing...
mmc_init: -95, time 14
Device 2: SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Vendor: 0x2207 Rev: V1.00 Prod: sfc_nor
            Type: Hard Disk
            Capacity: 16.0 MB = 0.0 GB (32768 x 512)
... is now current device
GUID Partition Table Header signature is wrong: 0xFFFFFFFFFFFFFFFF != 0x5452415020494645
** No partition table - mtd 2 **
Device 1:
Device 0: unknown device
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB...
No ethernet found.
Could not get mtd 0
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
Unknown command 'bootrkp' - try 'help'
Unlike the cm3 board, the rock5b board should use the mkimage script from the uboot directory.
$ubootName/tools/mkimage -C none -A arm -T script -n 'flatmax load script' -d $BR2_EXTERNAL_RK3308_PATH/board/RK3588/boot.cmd $BINARIES_DIR/boot.scr
This script now works as expected.
this patch will fix the source cmd
