Hi everyone,
I’m trying to run my application on the Radxa CM3 IO board using the following setup:
X11 + OpenGL (GPU) + Electron app + GStreamer renderer
However, I’ve noticed that X11 + OpenGL are currently running with CPU-based rendering (llvmpipe) instead of utilizing the ARM Mali GPU hardware .
I’m using the default image with kernel 5.10 , and I can confirm that the Mali driver is loaded ( /dev/mali0 is present).
Image used:
radxa-cm3-io_debian_bullseye_xfce_b27.img.xz
I have a few questions:
- Does X11 + OpenGL on Debian Bullseye (Debian 11) support GPU hardware acceleration on this platform?
- Are there any other RK3566-based boards (e.g., Radxa Zero 3 ) where X11 + OpenGL + GPU acceleration works out of the box, so I can use that as a reference?
- Would other frameworks such as Yocto or Armbian support GPU acceleration better in this setup?
- Has anyone here successfully achieved X11 + OpenGL + GPU acceleration on a similar platform?
Any pointers, configuration tips, or references would be greatly appreciated!
Thanks a lot for your time and support.
