System: armbian jammy gnome
Kernel: SDK kernel rkr3.6 from https://github.com/armbian/linux-rockchip/tree/rockchip-5.10/
I 'm using a HDMI2microHDMI cable to connect my rock3a and rock5b.
Here is the log when plug in the cable:
[ 262.714334] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 262.714350] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 262.737620] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 263.018991] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.07 (1648x750)
[ 263.229555] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 268.822504] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 268.822522] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 268.845785] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 269.136007] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 269.309747] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 270.049206] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 270.049223] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 270.072554] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 270.323110] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 270.352821] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 271.222569] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 271.222584] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 271.245845] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 271.336477] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 271.536057] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.06 (1648x750)
[ 288.663068] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 288.663083] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 288.686330] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 288.969907] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.06 (1648x750)
[ 289.577040] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 290.796529] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 290.796546] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 290.819808] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 291.103391] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 291.603773] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 308.690402] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 308.690420] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 308.713688] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 308.830978] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 309.005014] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.06 (1648x750)
[ 336.344581] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 336.344598] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 336.360103] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:2!
[ 336.640368] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 337.205205] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
After running GST_VIDEO_CONVERT_USE_RGA=1 gst-launch-1.0 -e v4l2src device=/dev/video0 ! videoconvert ! waylandsink, there come errors:
[ 420.056086] fdee0000.hdmirx-controller: Err, timing is invalid
[ 420.907081] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 420.907097] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 420.930359] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 421.211731] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 421.211834] fdee0000.hdmirx-controller: stream start stopping
[ 421.264379] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 421.264394] fdee0000.hdmirx-controller: stream stopping finished
[ 421.272363] fdee0000.hdmirx-controller: Err, timing is invalid
[ 421.314335] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 422.080465] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 422.080481] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 422.103742] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 422.327702] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 422.494322] fdee0000.hdmirx-controller: stream start stopping
[ 422.544425] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 422.544440] fdee0000.hdmirx-controller: stream stopping finished
[ 423.413847] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 423.413863] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 423.437133] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 423.727850] fdee0000.hdmirx-controller: stream start stopping
[ 423.781156] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 423.781169] fdee0000.hdmirx-controller: stream stopping finished
[ 424.354438] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 424.640542] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 424.640558] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 424.663818] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 424.945197] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 424.945287] fdee0000.hdmirx-controller: stream start stopping
[ 424.997847] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 424.997860] fdee0000.hdmirx-controller: stream stopping finished
[ 425.367807] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 425.867225] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 425.867239] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 425.890492] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 426.178494] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.06 (1648x750)
[ 426.178571] fdee0000.hdmirx-controller: stream start stopping
[ 426.231185] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 426.231193] fdee0000.hdmirx-controller: stream stopping finished
[ 426.381173] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 427.093929] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 427.093943] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 427.117193] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 427.394543] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 427.411668] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 427.411725] fdee0000.hdmirx-controller: stream start stopping
[ 427.464564] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 427.464572] fdee0000.hdmirx-controller: stream stopping finished
[ 428.320673] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 428.320688] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 428.343950] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 428.407910] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 428.627931] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.07 (1648x750)
[ 428.628027] fdee0000.hdmirx-controller: stream start stopping
[ 428.681321] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 428.681336] fdee0000.hdmirx-controller: stream stopping finished
[ 428.690192] fdee0000.hdmirx-controller: Err, timing is invalid
[ 429.547388] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 429.547402] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 429.570669] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 430.004237] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 430.004329] fdee0000.hdmirx-controller: stream start stopping
[ 430.054698] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 430.054711] fdee0000.hdmirx-controller: stream stopping finished
[ 430.434652] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 430.934105] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 430.934119] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 430.957378] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 431.278191] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.06 (1648x750)
[ 431.278285] fdee0000.hdmirx-controller: stream start stopping
[ 431.331469] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 431.331483] fdee0000.hdmirx-controller: stream stopping finished
[ 431.448023] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 432.187465] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 432.187480] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 432.202994] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:2!
[ 432.461388] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 432.494463] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 432.494559] fdee0000.hdmirx-controller: stream start stopping
[ 432.544847] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 432.544860] fdee0000.hdmirx-controller: stream stopping finished
[ 433.414197] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 433.414213] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 433.437490] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 433.474759] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 433.728830] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.07 (1648x750)
[ 433.728938] fdee0000.hdmirx-controller: stream start stopping
[ 433.781588] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 433.781602] fdee0000.hdmirx-controller: stream stopping finished
[ 433.790640] fdee0000.hdmirx-controller: Err, timing is invalid
[ 434.640876] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 434.640891] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 434.664156] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 434.945522] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 434.945617] fdee0000.hdmirx-controller: stream start stopping
[ 434.998197] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 434.998211] fdee0000.hdmirx-controller: stream stopping finished
[ 435.501491] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 435.867611] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 435.867626] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 435.890889] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 436.178913] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.07 (1648x750)
[ 436.179012] fdee0000.hdmirx-controller: stream start stopping
[ 436.231639] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 436.231653] fdee0000.hdmirx-controller: stream stopping finished
[ 436.514860] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 437.147656] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 437.147671] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 437.170927] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 437.463354] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p59.92 (1652x750)
[ 437.463445] fdee0000.hdmirx-controller: stream start stopping
[ 437.514960] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 437.514974] fdee0000.hdmirx-controller: stream stopping finished
[ 437.524140] fdee0000.hdmirx-controller: Err, timing is invalid
[ 437.531564] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 438.321020] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 438.321034] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 438.344292] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 438.541598] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 438.773294] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.06 (1648x750)
[ 438.773388] fdee0000.hdmirx-controller: stream start stopping
[ 438.825011] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 438.825025] fdee0000.hdmirx-controller: stream stopping finished
[ 439.203093] fdee0000.hdmirx-controller: stream start stopping
[ 439.255073] fdee0000.hdmirx-controller: hdmirx_stop_streaming wait last irq timeout, return bufs!
[ 439.255087] fdee0000.hdmirx-controller: stream stopping finished
[ 439.554975] rk_hdmirx fdee0000.hdmirx-controller: audio on
[ 439.707719] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 1
[ 439.707734] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 439.730997] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:3!
[ 440.057035] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1280x720p60.07 (1648x750)
[ 440.568337] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 440.568346] rk_hdmirx fdee0000.hdmirx-controller: audio off
I don’t have this issue on another rk3588 board h88k, which has a HDMI type A HDMI-In port.
