I just setup my nas with the SATA Hat and the Hat Top, fan is working fine but I canβt get the OLED to display anything. Does anyone know how to get it working on RPI 5 running bookworm?
Cheers
Cheers
Itβs i2c OLED display, so You should see itβs address via i2cdetect utility:
$ i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- 51 -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- --
If there is nothing detected - duble check if i2c protocol is turned on, then double check connection.
Hi @Shaun_Nicholson,
Please refer to here[1] to install the software package.
[1] https://docs.radxa.com/en/accessories/penta-sata-hat/sata-hat-top-board
Iβm getting this:
pi@raspberrypi:~ $ i2cdetect -y 1
00: β -- β -- β -- β --
10: β -- β -- β -- β -- β -- β -- β -- β --
20: β -- β -- β -- β -- β -- β -- β -- β --
30: β -- β -- β -- β -- β -- β -- β -- β --
40: β -- β -- β -- β -- β -- β -- β -- β --
50: β -- β -- β -- β -- β -- β -- β -- β --
60: β -- β -- β -- β -- β -- β -- β -- β --
70: β -- β -- β -- β --
I installed the software package, checked the connections the fan is spinning just the OLED not displaying anything.
Also the fan speeds donβt seem to be controlled and when I double press the button the fan doesnβt stop spinning either.
This is the one I ordered: https://nl.rs-online.com/web/p/rock-sbc-add-ons/2565002?gb=s
Obviously i2c device is not connected, is i2c protocol enabled in raspi-config?
It is enabled, I just got a new one in the mail and this one does work. Seems like the one I had before was faulty. All sorted.
One question regarding the screen, is it possible to get the readings of omv zfs pool on there instead of the sd card?
We can update the program to specify a path to the config file.
Please help. @Shawn
Is there a way to display other hdd information instead of the raspberry pi sd card?
Simple python script is used to display those,
just modify it with paths and information You need: /usr/bin/rockpi-sata/misc.py
save and restart service
Do you happen to have an example code how to achieve this?
Itβs very simple script, try yourself to alter few lines, itβs easy to test it and make some modifications.
Probably my version will not work on Your side and I donβt remember what I changed there (my unit is out of sight now).
I have no idea, so if someone has an example script by any chance I could modify it. Thanks
Iβve received the topboard today, installed it, double-checked the connections, run the update Setq suggested. Nothing happens, the fan wonβt come on, no leds blinkingβ¦
Hey Shaun,
I have the same problem, I also ordered from RS
https://befr.rs-online.com/web/p/rock-sbc-add-ons/2565002.
When I run the i2detect script I get 3c on the vertical 30 horizontal c line
So I should send RS an email explaining the problem, maybe I can also get a new one
Hi, I ordered another one and that worked. Mine was faulty. You can probably return it to RS no problem.
If someone has an example script, would like to take a look
