Hardware H.264 Encoding with GStreamer on Radxa Cubie A5E
I am using a Radxa Cubie A5E with Radxa OS – Debian 11 Bullseye and am trying to run a GStreamer pipeline for H.264 video encoding using the board’s hardware encoder.
I am looking for explicit, Cubie A5E–specific guidance on the following:
1. Supported Hardware Encoder
  • Which H.264 hardware encoder is supported on Cubie A5E under Debian 11?
  • Is the encoder exposed through:
    • v4l2h264enc
    • omxh264enc
    • cedarc
    • or a Radxa-specific GStreamer plugin?
2. Required Packages and Versions
  • Exact package names required for enabling hardware H.264 encoding (GStreamer core and plugins, V4L2, OMX, CedarX, etc.)
  • Minimum required versions of:
    • GStreamer
    • Kernel
    • V4L2 / media drivers
  • Whether Radxa-patched packages are required instead of upstream Debian packages
3. Verified Working Pipeline Examples
I am specifically looking for tested and confirmed working gst-launch-1.0 examples on Cubie A5E, such as:
  • CSI/MIPI camera → H.264 → MP4 file
  • USB camera (MJPEG or YUYV) → H.264 → MP4 file
  • Raw frames → H.264 → RTP/UDP stream
My goal is to follow the official and recommended approach for hardware H.264 encoding on this platform and avoid trial-and-error with unsupported plugins.
If there is existing documentation, sample scripts, or a reference repository for Cubie A5E video encoding, please share a link.
Thanks in advance.
Any update on this query?
If hardware H.264 encoding on Radxa Cubie A5E is not fully supported on Radxa OS (Debian 11 Bullseye), is there an alternative Radxa-supported OS?
I’m looking for exactly the same but for Cubie A7Z (also Radxa OS Debian 11 Bullseye). I need answers to the exact same questions… kind of angry already that the advertisement is very misleading - the camera stack barely works, and now encoding also doesn’t work :face_with_symbols_on_mouth:
I have made an issue on their git regarding this:
https://github.com/radxa-build/radxa-cubie-a5e/issues/5
They gave me a solution that instructs you to compile the tools manually, but the links they provided for the dependencies (like mpp and gstreamer-rockchip) are actually taken down/dead. I am currently asking them for valid mirrors or a proper package solution.
You can follow that issue for updates.
Omfg ! I knew i was not going crazy over this.. I’ve been trying to make the 4k radxa mipi camera working for days - From Gstreamer to FF.
Nothing works, specially when they said “hardware/accessories” compatible & overlays are showing the camera. It is ticked but i’m sure we missing depedencies / repository.
still no solutions? anyone?
