Hardware decoding for video not enabled on A7A
Hardware acceleration for media playback not enabled on A7A, Radxa team must fix it.
@feng Hello sir, please do something to this problem
What format of video file are you playing? Additionally, what media player or playback method are you using
At chromium browser, at 1080p frame dropped, at 4k video lagging. Also chromium showing that hardware acceleration not enabled.
@feng Sir, the video file format is mp4
Allwinner has feedback that the browser hardware decoding support is still under development. You can first use GStreamer to play video files encoded in H264, H265, VP9, or AVS formats as a test.
@feng I’m trying to use the hardware decoder for RTSP stream with ffmpeg which I’ve installed but it was not able to decode the RTSP stream video frames which is H264/H265 encoded . I tried with media pipe example given ( MediaPipe Examples | Radxa Docs ) with just replaced the image source as RTSP URL but it didn’t work . Can you route me to the right direction please . it’s better if I can use the media pipe to pull rtsp stream and view it with cv2 first .
Regards,
Amir
you can also use dragonplayer “dragon <videopath.mp4>” But I doubt whether it’s hardware decoding or not . I was not able to use CV2 yet for RTSP stream to pull read docode and show .
Finally , I have managed to make it work . Here’s how .
Install gstreamer and ffmpeg
sudo apt update
sudo apt install gstreamer1.0-tools gstreamer1.0-libav
gstreamer1.0-plugins-good gstreamer1.0-plugins-bad
ffmpeg libavcodec-dev libavformat-dev libavutil-dev libswscale-dev
Install gstreamer python3 libraries
sudo apt install -y python3-gi python3-gst-1.0 gstreamer1.0-python3-plugin-loader
add user group and permission to /dev/cedra_dev
sudo usermod -aG video radxa
sudo chmod 666 /dev/cedar_dev
logout
login
Python3 script: gst_rtsp_pull.py
import gi
gi.require_version(“Gst”, “1.0”)
from gi.repository import Gst
import numpy as np
import cv2
Gst.init(None)
pipeline_str = (
"rtspsrc location=rtsp://example.com:554/live/0 protocols=tcp latency=100 ! "
"rtph265depay ! h265parse ! "
"omxhevcvideodec ! "
"videoconvert ! "
"video/x-raw,format=BGR ! "
“appsink name=appsink emit-signals=true drop=true max-buffers=1 sync=false”
pipeline = Gst.parse_launch(pipeline_str)
appsink = pipeline.get_by_name(“appsink”)
pipeline.set_state(Gst.State.PLAYING)
print(“? GStreamer HW decode started”)
while True:
sample = appsink.emit(“pull-sample”)
buffer = sample.get_buffer()
caps = sample.get_caps()
width = caps.get_structure(0).get_value("width")
height = caps.get_structure(0).get_value("height")
success, mapinfo = buffer.map(Gst.MapFlags.READ)
if not success:
    continue
frame = np.ndarray(
    (height, width, 3),
    dtype=np.uint8,
    buffer=mapinfo.data
cv2.imshow("RTSP HW Decode", frame)
buffer.unmap(mapinfo)
if cv2.waitKey(1) & 0xFF == 27:
    break
pipeline.set_state(Gst.State.NULL)
cv2.destroyAllWindows()
Open Terminal & export display port to help OpenCV environment variable
export DISPLAY=:1
export XDG_RUNTIME_DIR=/run/user/$(id -u)
xhost +local:root
Execute the python3 script to pull rtsp stream → Hardware Decode → show on screen
sudo -E python3 gst_rtsp_pull.py
