Hmm, the fan control driver should be in the kernel. Did you connect the fan to the proper port?
Also the default curve is just bad, use this one: [Guide] How to make the Rock 5b fan work properly - Joshua Riek's Ubuntu 24.04
Some additional information:
in property pwms = <&pwm1 0 10000 0>;, the first number is the pwm channel in this device, second number is pwm period(1/pwm frequency), the third number is pwm polarity.
Do I just need to modify the values in pwm-fan.dts and rerun sudo armbian-add-overlay pwm-fan.dts to change the fan curve once we’ve already set it once?
Yes. Reboot then you will run with new fan curve.
Is there a known method to customize the fan curve on the official Radxa image?
I have upgrade my Kernel from 5.x to Linux 6.1.115-vendor-rk35xx
now i cannot view the PWM speed anymore:
cat /sys/devices/platform/pwm-fan/hwmon/hwmon8/pwm1
cat: /sys/devices/platform/pwm-fan/hwmon/hwmon8/pwm1: No such file or directory
this worked before it upgraded the kernel.
anyone knows what I am doing wrong?
found the solution.
it changed to
cat /sys/class/hwmon/hwmon9/pwm1
You can do hwmon? for the wildcard to do it for you
