1. Required Resources
- BIOS Version:
edk2-cix 1.0.0-2 - Debian 12 Pre-installed Image:
Download Link (Third-party Images → Debian12)
2. Compatibility Note
The default Debian 12 image ships with Linux Kernel 6.1. However, the CIX Panthor driver is supported only from Linux Kernel 6.6 onward. Therefore, you will need to build and replace the kernel with version 6.6.
3. Download and Build CIX Kernel 6.6
3.1 Obtain CIX SDK Source Code
Reference: CIX SDK Source
mkdir cix-sdk
cd cix-sdk
repo init https://gitlab.com/cix-linux/linux_repo/cix-manifest.git -b origin/ee8f6/48bff/cix_p1_K6.6_2025Q3_dev
repo sync
3.2 Compile the Linux Kernel
Reference: CIX SDK Build Guide
cd cix-sdk
source build-scripts/envtool.sh
build kernel
Note:
DT version of the Panthor driver is enabled by default on the cix_p1_K6.6_2025Q3_dev branch (no extra modification needed).
ACPI version requires you to apply this patch
4. Replace the Debian 12 Kernel
4.1 Replace Kernel Files
cd cix-sdk/output/cix_evb
# Copy files to your Orion O6 machine
scp Image sky1-orion-o6.dtb <orion-o6-ip>:/tmp/
On the Orion O6 device:
sudo su root
mkdir /mnt/data_boot
mount /dev/nvme0n1p1 /mnt/data_boot/
cp /tmp/Image /tmp/sky1-orion-o6.dtb /mnt/data_boot/
sync
4.2 Install New Kernel Packages
Copy the following .deb files from cix-sdk/output/cix_evb/debs/ to any directory on Orion O6:
- linux-headers-6.6.89-xxx.deb
- linux-image-6.6.89-xxx.deb
- linux-libc-dev_6.6.89-xxx.deb
Install them with:
dpkg -i linux-headers-6.6.89-xxx.deb
dpkg -i linux-image-6.6.89-xxx.deb
dpkg -i linux-libc-dev_6.6.89-xxx.deb
5. Enable the Panthor Driver
5.1 Disable the Default mali_kbase Driver
Edit /usr/bin/load-modules.sh and comment out the following lines:
#insmod /lib/modules/$linux_version/extra/protected_memory_allocator.ko
#insmod /lib/modules/$linux_version/extra/memory_group_manager.ko
#insmod /lib/modules/$linux_version/extra/mali_kbase.ko
Then load the panthor driver:
modprobe panthor
5.2 Adapt the linlondp Driver
The linlondp driver enables the render node by default, which conflicts with the panthor driver’s usage. To disable it:
touch /etc/modprobe.d/linlon-dp.conf
echo "options linlon-dp enable_render=0" > /etc/modprobe.d/linlon-dp.conf
6. Mesa Panfrost Driver Compilation and Configuration
6.1 Build Mesa Panfrost on Orion O6
# download mesa code
wget https://gitlab.freedesktop.org/mesa/mesa/-/archive/25.1/mesa-25.1.tar.gz
tar -zxf mesa-25.1.tar.gz
# update meson
echo "deb http://deb.debian.org/debian bookworm-backports main" | tee /etc/apt/sources.list.d/backports.list
apt update
apt install -t bookworm-backports meson
apt install -y build-essential meson ninja-build pkg-config
apt install cmake git libclc-19-dev python3-mako python3-yaml zlib1g-dev libexpat1-dev libdrm-dev libudev-dev
apt install llvm-15 llvm-15-dev clang-15 libclang-15-dev lld-15 liblld-15-dev libllvm15 llvm-15-tools libllvmspirvlib-15-dev
# build and install spirv-tools
git clone https://github.com/KhronosGroup/SPIRV-Tools.git
cd SPIRV-Tools/
git checkout vulkan-sdk-1.3.296
cd SPIRV-Tools/external/
git clone https://github.com/KhronosGroup/SPIRV-Headers.git
mv SPIRV-Headers/ spirv-headers/
cd spirv-headers/
cd ../..
mkdir build && cd build
cmake -DCMAKE_INSTALL_PREFIX=/usr/local ..
make install -j10
# build and install waylands
wget https://gitlab.freedesktop.org/wayland/wayland/-/releases/1.23.0/downloads/wayland-1.23.0.tar.xz
tar -xf wayland-1.23.0.tar.xz
cd wayland-1.23.0/
meson setup build --prefix=/usr -Ddocumentation=false
ninja -C build install
# build and install wayland-protocols
wget https://gitlab.freedesktop.org/wayland/wayland-protocols/-/archive/1.41/wayland-protocols-1.41.tar.gz
tar -xvf wayland-protocols-1.41.tar.gz
cd wayland-protocols-1.41/
apt install libelf-dev libssl-dev libpng-dev byacc bison flex
apt install libxcb-dri3-dev libxcb-randr0-dev libx11-dev libxext-dev libxfixes-dev libxcb-glx0-dev libxcb-shm0-dev
apt install libx11-dev libx11-xcb-dev libx11-dev libxcb-present-dev libxshmfence-dev libxxf86vm-dev libxrandr-dev ocl-icd-opencl-dev
cp /usr/lib/llvm-15/lib/clang/15.0.6/include/opencl-c-base.h code/mesa-25.1/include/
cp /usr/lib/llvm-15/lib/clang/15.0.6/include/opencl-c.h code/mesa-25.1/include/
# build and install mesa
cd mesa-25.1
meson . build/ --reconfigure -Dprefix=/usr -Dgallium-drivers=panfrost -Dvulkan-drivers=panfrost -Dbuildtype=release
6.2 Debian System Configuration
- Backup and delete the following directories, these files will conflict with the Panfrost driver :
- /opt/cixgpu-compat
- /opt/cixgpu-pro
- Replace Xwayland with the default system version:
- apt install xwayland=2:22.1.9-1
- Delete the following Vulkan configuration files if they exist:
- /etc/vulkan/icd.d/mali.json
- /etc/vulkan/implicit_layer.d/VkLayer_window_system_integration.json
7. Final Steps and Verification
7.1 Reboot System
Reboot your Orion O6 device for the Panthor and Panfrost drivers to take effect
7.2 Verification
Check if the Panthor Driver is Loaded
After reboot, check the kernel logs for confirmation:
DT Version:
root@orion-o6:/home/radxa# dmesg | grep panthor
[ 2.646559] [pid:313,cpu3,(udev-worker)]panthor 15000000.gpu: [drm] clock rate = 900000000
[ 2.646615] [pid:313,cpu3,(udev-worker)]panthor 15000000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[ 2.652245] [pid:313,cpu0,(udev-worker)]panthor 15000000.gpu: [drm] mali-unknown id 0xc870 major 0x0 minor 0x0 status 0x8
[ 2.652250] [pid:313,cpu0,(udev-worker)]panthor 15000000.gpu: [drm] Features: L2:0x8130306 Tiler:0x809 Mem:0x301 MMU:0x2830 AS:0xff
[ 2.652253] [pid:313,cpu0,(udev-worker)]panthor 15000000.gpu: [drm] sky1_harvesting_reg_val=0xf sky1_harvesting_core_mask=0x550555
[ 2.652255] [pid:313,cpu0,(udev-worker)]panthor 15000000.gpu: [drm] shader_present=0x550555 l2_present=0x1 tiler_present=0x1
[ 2.654872] [pid:313,cpu7,(udev-worker)]panthor 15000000.gpu: [drm] Firmware protected mode entry not be supported, ignoring
[ 2.654937] [pid:313,cpu7,(udev-worker)]panthor 15000000.gpu: [drm] Firmware git sha: 17edf0fe034e91ac1779419ce5413342a2fb535e
[ 2.655241] [pid:313,cpu7,(udev-worker)]panthor 15000000.gpu: [drm] CSF FW using interface v3.13.0, Features 0x10 Instrumentation features 0x71
[ 2.656805] [pid:313,cpu10,(udev-worker)][drm] Initialized panthor 1.2.0 20230801 for 15000000.gpu on minor 0
ACPI Version:
[ 9.276118] [pid:336,cpu10,(udev-worker)]panthor CIXH5000:00: [drm] clock rate = 900000000
[ 9.295007] [pid:336,cpu10,(udev-worker)]panthor CIXH5000:00: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[ 9.311693] [pid:336,cpu9,(udev-worker)]panthor CIXH5000:00: [drm] mali-unknown id 0xc870 major 0x0 minor 0x0 status 0x8
[ 9.311701] [pid:336,cpu9,(udev-worker)]panthor CIXH5000:00: [drm] Features: L2:0x8130306 Tiler:0x809 Mem:0x301 MMU:0x2830 AS:0xff
[ 9.311707] [pid:336,cpu9,(udev-worker)]panthor CIXH5000:00: [drm] shader_present=0x550555 l2_present=0x1 tiler_present=0x1
[ 9.313626] [pid:336,cpu9,(udev-worker)]panthor CIXH5000:00: [drm] Firmware protected mode entry not be supported, ignoring
[ 9.313683] [pid:336,cpu9,(udev-worker)]panthor CIXH5000:00: [drm] Firmware git sha: 17edf0fe034e91ac1779419ce5413342a2fb535e
[ 9.313869] [pid:336,cpu10,(udev-worker)]panthor CIXH5000:00: [drm] CSF FW using interface v3.13.0, Features 0x10 Instrumentation features 0x71
[ 9.314137] [pid:336,cpu9,(udev-worker)][drm] Initialized panthor 1.2.0 20230801 for CIXH5000:00 on minor 0
[ 9.318996] [pid:336,cpu0,(udev-worker)]<dst::do_boottime_initcall:99> initcall panthor_init+0x0/0x1000 [panthor] returned 0 after 86794 usecs
Check if Panfrost is Working:
After the Debian desktop environment starts, go to: Settings → About → Graphics
You should see “Mali-G720(Panfrost)” or a related entry displayed.
If you see the panthor and panfrost information as described above, the drivers have been enabled successfully.
Run glmark2:
Run vkcube:
Note:
If using Mesa Panfrost 25.2 or above, Xwayland 24.1 or newer is required; otherwise, X11 applications might not run correctly.
Build and Install Xwayland 24.1 on Orion O6
# update xorgproto
git clone https://gitlab.freedesktop.org/xorg/proto/xorgproto.git
cd xorgproto
# update libdrm
git clone https://gitlab.freedesktop.org/mesa/libdrm.git
cd libdrm/
git checkout libdrm-2.4.125
meson setup build -Dprefix=/usr
apt install libpixman-1-dev libxkbfile-dev libxfont-dev libxcvt-dev libepoxy-dev libxcb-dri2-0-dev
# get the xserver code and checkout to xwayland-24.1 branch
git clone https://gitlab.freedesktop.org/xorg/xserver.git
cd xserver
git checkout xwayland-24.1
meson setup build --prefix=/usr -Ddocs=false
systemctl stop gdm
cp build/hw/xwayland/Xwayland /usr/bin/
systemctl start gdm
