Green image when using two Radxa 4k cameras and framerate capped at 30fps
I recently got a Radxa 5B+ with two Radxa Camera 4k modules. My intention is to connect them both to the 5B+ and use them simultaneously. I am however running into some issues:
  • Only one of the cameras displays a proper image. The image from the other camera has a green shade to it. This seems to be a problem with the rkaiq_3A_server only preprocessing one of the cameras and not both. I have been able to get a proper picture out of each of the cameras separately (connected to the CAM0 and CAM1 ports), but when enabling both at the same time, only one of the two looks proper.
  • The frame rate of the cameras is capped at 30fps, irrespective of the selected resolution. This is also the case when only one camera is connected to the board.
I am running Joshua Riek’s Ubuntu 24.04 LTS and I am using gstreamer to access the cameras. I have already tried installing different versions of the rkaiq_3A_server, but without much success.
