I just started to test my Radxa X4 board (12gb ram with ssd mounted) under Windows 11 24h2 version.
When I try to install the sound driver, it gives 0x0000007 error. Windows does not recognize the sound chip. I see not available icon in the place of the speaker.
Second problem, system works ok with the basic display adapter from Microsoft. When I install it’s driver, right after the installation it shows black screen only with the cursor. I cannot see the file explorer.
What I tried:
Install the graphic driver from Radxa’s site
Install the driver from Windows Update
Install the driver from Intel’s website
Updated the bios
I can enter to Windows only after running Windows under safe mode, uninstall the graphics driver with Display Driver Uninstaller (DDU) and restart Windows. And of course, Windows installs the new driver automatically and after a minute I get the black screen back.
How can I solve those problems? Is it a software issue or hardware?
I reformatted the drive and downgraded Windows to 23H2. I tried to install all the driver options from above. The sound card driver could install but the graphics driver could not be installed.
After installing the graphics driver, all I see is a black screen with cursors, few times resetting the monitor, later a BSOD - video_tdr_failure. After few times Windows disables the graphics card and I can see the screen. On device manager there is an exclamation on the graphics card and says that
“Windows stopped the device because it has problem”.
If there is a solution under Windows (I am not planning to use Linux so far), if others can install the same driver without problem and I cannot, I started to think it is a hardware problem.
