Hello again !
I followed the instructions to use libgpiod on a radxa on the wiki. I run Ubuntu server edition on a Radxa Zero. It installs fine. Running sudo gpioinfo returns :
gpiochip0 - 85 lines:
line 0: unnamed unused input active-high
line 1: unnamed unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 4: unnamed unused input active-high
line 5: unnamed unused input active-high
line 6: unnamed unused input active-high
line 7: unnamed unused input active-high
line 8: unnamed unused input active-high
line 9: unnamed unused input active-high
line 10: unnamed unused input active-high
line 11: unnamed unused input active-high
line 12: unnamed unused input active-high
line 13: unnamed unused input active-high
line 14: unnamed unused input active-high
line 15: unnamed unused input active-high
line 16: unnamed unused input active-high
line 17: unnamed unused input active-high
line 18: unnamed unused input active-high
line 19: unnamed unused input active-high
line 20: unnamed unused input active-high
line 21: unnamed unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: unnamed "regulator-vcc_5v" output active-low [used open-drain]
line 25: unnamed unused output active-high
line 26: unnamed unused input active-high
line 27: unnamed unused output active-high
line 28: unnamed unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
line 32: unnamed unused input active-high
line 33: unnamed unused input active-high
line 34: unnamed unused input active-high
line 35: unnamed unused input active-high
line 36: unnamed unused input active-high
line 37: unnamed "reset" output active-low [used]
line 38: unnamed unused input active-high
line 39: unnamed unused input active-high
line 40: unnamed unused input active-high
line 41: unnamed unused input active-high
line 42: unnamed unused input active-high
line 43: unnamed unused input active-high
line 44: unnamed unused input active-high
line 45: unnamed unused input active-high
line 46: unnamed unused input active-high
line 47: unnamed "cd" input active-low [used]
line 48: unnamed unused input active-high
line 49: unnamed unused input active-high
line 50: unnamed unused input active-high
line 51: unnamed unused input active-high
line 52: unnamed unused input active-high
line 53: unnamed unused input active-high
line 54: unnamed unused input active-high
line 55: unnamed unused input active-high
line 56: unnamed unused input active-high
line 57: unnamed unused input active-high
line 58: unnamed unused input active-high
line 59: unnamed unused input active-high
line 60: unnamed unused input active-high
line 61: unnamed unused input active-high
line 62: unnamed unused input active-high
line 63: unnamed unused input active-high
line 64: unnamed unused input active-high
line 65: unnamed unused input active-high
line 66: unnamed unused input active-high
line 67: unnamed unused input active-high
line 68: unnamed unused input active-high
line 69: unnamed unused input active-high
line 70: unnamed unused input active-high
line 71: unnamed "reset" output active-low [used]
line 72: unnamed unused input active-high
line 73: unnamed unused input active-high
line 74: unnamed unused input active-high
line 75: unnamed unused input active-high
line 76: unnamed unused input active-high
line 77: unnamed unused input active-high
line 78: unnamed unused input active-high
line 79: unnamed unused input active-high
line 80: unnamed unused input active-high
line 81: unnamed unused input active-high
line 82: unnamed "shutdown" output active-high [used]
line 83: unnamed unused input active-high
line 84: unnamed unused input active-high
gpiochip1 - 15 lines:
line 8: unnamed "radxa-zero:green" output active-high [used]
If I compare this output with the one on the wiki (supposedly a Radxa Rockchip), I can see that all pins are unnamed on the RZ. But the interface seems functional.
Is gpiod supported on Radxa Zero ?
