According to this pinout:
https://wiki.radxa.com/Rock5/hardware/5b/gpio
Yes!
I only update the GPIO’s address for pins 16 and 18 on a previous answer…
Yes!
I’ve tested Callbacks for IRQ and it worked for me!
could you send me the python script you used to test callbacks so I can test on my radxa5?
following is the script I am testing, I have a rain gauge hooked to pin 23. I didn’t bother with radxa file for pins, just changed the pin mapping file.
#!/usr/bin/python3
import time
import sys
import OPi.GPIO as GPIO
GPIO.setwarnings(False)
channel = 23
GPIO.setmode(GPIO.BOARD)
GPIO.setup(channel, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
rainTick = 0 # Count of the rain input trigger
interval = 5 # Set now to define scope of variable
rainTime = 0 # Use this to detect erroneous rain events
def raintrig(channel):
time.sleep(0.02) #added 05-12-2020 to see if helps error in rain waits 10ms
global rainTick
global rainTime
rainTick += 1
print(“in raintrig”, rainTick)
GPIO.add_event_detect(channel, GPIO.FALLING, callback=raintrig)
GPIO.add_event_callback(channel, raintrig)
while True:
print(‘Reading…’)
if GPIO.input(channel) == GPIO.LOW:
print(‘Pressed’)
else:
print(‘Released’)
time.sleep(2)
You can try:
import time
import sys
channel = 23
GPIO.cleanup()
time.sleep(1)
GPIO.remove_event(channel)
global rainTick
global rainTime
rainTick += 1
while True:
print(‘Reading…’)
print(‘Pressed’)
else:
print(‘Released’)
time.sleep(2)
I put a 330 ohm resistor in the circuit. I added GPIO.cleanup(). Changed the warnings to true. I am running the script thru Thonny so doubt it matters.
Ran the script again with the changes and no difference
RPi
I have been running this basic script using RPi.GPIO on a raspberry for over 3 years. It is running right now. That is why this is so frustrating.
Please send me the python script that you tested callback so I can test my here, Thanks
Please check this snippet , I test it on a a radxa CM3 board.
Modify the required parameters.
Also, I made a mistake in my previous reply. You cannot GPIO.cleanup() after GPIO.setup() the pin. Sorry for that.
Check this out:
import time
import radxa.radxa_cm3_io
from OPi import GPIO as GPIO
GPIO.cleanup()
time.sleep(5)
GPIO.setmode(radxa.radxa_cm3_io.SBC)
pin = 19
pin2 = 15
i=0
def interrupt(var):
global i
i=i+1
print(f"event number {i}")
print(f"Event triggered by pin: {var}")
#GPIO.setwarnings(False)
try:
GPIO.setup(pin, GPIO.IN)
GPIO.remove_event_detect(pin)
GPIO.setup(pin2, GPIO.IN)
GPIO.remove_event_detect(pin2)
# time.sleep(5)
# print( GPIO.input(pin) )
GPIO.add_event_detect(pin, GPIO.FALLING, callback=interrupt)
GPIO.add_event_detect(pin2, GPIO.FALLING, callback=interrupt)
while True:
print( f"Pin number { pin } is: { GPIO.input(pin) } " )
print( f"Pin number { pin2 } is: { GPIO.input(pin2) } " )
time.sleep(1)
except KeyboardInterrupt:
pass
finally:
GPIO.cleanup()
radxa cm3 io uses a different cpu chip so I don’t know why the code would run on radxa5 just because it runs on cm3.
Also this can’t be python3 script as the indents all mostly wrong. Also I can’ run
import radxa.radxa_cm3_io on radxa5.
From Thonny:
File “/home/pi/OPiTest6.py”, line 22, in
File “/home/pi/.local/lib/python3.9/site-packages/OPi/GPIO.py”, line 477, in setup
sysfs.unexport(pin)
File “/home/pi/.local/lib/python3.9/site-packages/OPi/sysfs.py”, line 45, in unexport
fp.write(str(pin))
OSError: [Errno 22] Invalid argument
thanks for all your suggestions, hope someone with an radxa5 will pitch in with some answers.
