So i bought prebooked rock 5b when it got released, so got a coupon, and one of the few people to order it when it was released,
after i got the board, i tried multiple power supplies, wasted so much money for power supplies, and even bought the official radxa power supply and tried booting it,
and that too failed.
after reaching out to the allnetchina for this issues, they wanted me to ship the board back to china, which was quite impossible, and there is no way i can send it from my country.
i had travelled to china for some work visit, and i took the board with me to china and then shipped it locally to allnetchina office, and they took good amount of time and found that there was a faulty ic and they assured me that it is fixed and shipped me the board, after i received the board, i tried booting most of the images that were available and none of them booted, only radxa image that was then available booted. none of the other images boot on my rock 5b.
i tried reaching the allnetchina team for their support and they arent responding.
these boards are capable, but when the manufacturer makes a mistake by sending untested dead board to customers, why should i a customer face all the trouble to get it fixed, and when i took the long way to send it back for rma, they screw me again, they sent back a faulty board, they didnt even replace the whole board and give me a working one instead.i am totally vexed with this board.
this is the serial out that i am getting when trying to boot armbian, if any one can help please do.
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/serial0, 22:36:39
Press CTRL-A Z for help on special keys
DDR 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
Manufacturer ID:0x6
CH0 RX Vref:29.3%, TX Vref:23.8%,23.8%
CH1 RX Vref:28.8%, TX Vref:23.8%,24.8%
CH2 RX Vref:27.9%, TX Vref:24.8%,23.8%
CH3 RX Vref:29.3%, TX Vref:21.8%,21.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45
NOTICE: BL31: Built : 10:11:21, Dec 27 2023
INFO: spec: 0x1
INFO: code: 0x88
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: l3 cache partition cfg-0
INFO: system boots from cpu-hwid-0
INFO: disable memory repair
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE iniK
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
thanks
