Ggml model on HiFi 5 DSP in Orion O6
I’d like to understand the feasibility of porting a GGML model to the HiFi 5 DSP in the SoC, particularly with respect to the memory accessible by the DSP. Based on the core configuration shown here ( Radxa Orion O6 | Tensilica Tools ), the System RAM region starting at 0x20400000 appears to be only 1 MB in size. Is this System RAM mapped to the LPDDR5 memory, or is it a separate on-chip memory region? Additionally, where can I find detailed documentation on the SoC memory map, including the HiFi 5 memory architecture and its access to system memory? Thanks.
The HiFi5 DSP actually has 384k of local RAM (in three banks of 128KB) plus 1MB of on-chip external SRAM (from 0x20400000) as well as a mapped 2MB window for host communications (not all of which is allocated by default) and 16MB LPDDR-backed DSP working memory plus a second 16MB LPDDR-backed XAF client data pool. However the first 16MB is scratch-memory and state, so only the second 16MB would be available for weights, etc.
Your challenges would therefore be that you’ll struggle to fit a full model into 16MB, and offloading individual small operations would probably not be worthwhile due to the communications overhead.
You’d also not be able to productively use generic GGML C code, but instead would have to re-write the model as Xtensa/HiFi SIMD matrix and quantisation kernels, probably as custom XAF components.
The CIX P1 TRM omits detailed HiFi5-local and LPDDR-window architecture detail, so it’s difficult to know how amenable the DSP would be to enlarging the client-pool beyond 16MB in size – which would also require custom DSP- as well as system- firmware.
Thank you for your response, Stuart. With CIX’s engineering’s help, and using the Cadence lllama.cpp for HiFi 5s, GitHub - foss-xtensa/llama.cpp-hifi: Xtensa HiFi5s/iQ bare-metal port of llama.cpp -- LLM inference on Xtensa DSP · GitHub , I was able to get 0.5B Qwen GGUF model functional on the Orion O6 now. Instead of XAF, the GGML is built on top of SOF. I’m benchmarking the performance (tokens per second) and trying to minimize the latency from DDR …
