Would be balbes150’s builds as described in the link in the original post the right way to get started if you want to use the Radxa Zero as a server (and not as a media player) and need a good package manager?
How should the content of the extlinux.conf look like for the Radxa Zero?
Hi There
An noob on the OS.
I hit some dependency issues with update for the twister os
is this normal?
You might want to run ‘apt --fix-broken install’ to correct these.
linux-libc-dev : Breaks: linux-libc-dev:armhf (!= 5.4.0-80.90) but 21.08.2 is installed
linux-libc-dev:armhf : Breaks: linux-libc-dev (!= 21.08.2) but 5.4.0-80.90 is installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
