Flashing Ubuntu to eMMC
I seem to have issues flashing Ubuntu to eMMC on Windows. Here’s how it went for me.
I started having a brand new Raxda Zero 8GB with Android. It booted to Android fine. I was able to install Zagdig USB device, as well as Android driver. I am able to see libusb-win32 device (GX-CHIP) in Device Manager.
  1. I watch some YouTube video and started by downloading and sideloading factory-loader.img <— I think this is where I must hack whacked the bootloader
  2. i read more and used radxa-zero-erase-emmc.bin, after which a USB device pops up, I have to format it with FAT32, and after that using balenEtcher I burn radxa-cm3-io-ubuntu-focal-server-arm64-20220315-1221-gpt.img to it. I turn off/on Raxda
  3. Nothing happens in HDMI output, in serial I get:
    G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:20000;USB:8;
  4. If i try to sideload u-boot.bin i get the following output
l2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 34617716
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 2
DATA transfer complete...
fw parse done
AML DDR FW load done
PIEI prepare done
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
Check phy result
1D init succeed
Check phy result
channel==0
RxClkDly_Margin_A0==236 ps 12
TxDqDly_Margin_A0==256 ps 13
RxClkDly_Margin_A1==236 ps 12
TxDqDly_Margin_A1==256 ps 13
TrainedVREFDQ_A0==74
TrainedVREFDQ_A1==74
VrefDac_Margin_A0==23
DeviceVref_Margin_A0==40
VrefDac_Margin_A1==24
DeviceVref_Margin_A1==40
channel==1
VrefDac_Margin_A0==24
soc_vref_reg_value 0x 00000014 00000013 00000012 00000015 00000014 00000012 0000        0014 00000013 00000013 00000015 00000015 00000015 00000015 00000015 00000015 000        00013 00000015 00000014 00000015 00000014 00000015 00000014 00000016 00000016 00        000012 00000014 00000015 00000015 00000014 00000014 00000013 00000015 dram_vref_        reg_value 0x 0000005d
2D init succeed
ddr init done, boot next stage
result report
auto size-- 65535DDR cs0 size: 1024MB
DDR cs1 size: 1024MB
DMC_DDR_CTRL: 00e0001bDDR size: 2048MB
cs0 DataBus test pass
cs1 DataBus test pass
cs0 AddrBus test pass
cs1 AddrBus test pass
Data req end
RUN bl2 usb boot
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
28 0b 30 00 01 36 16 00 00 14 35 39 53 42 56 50
[0.017150 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE:  BL31: v1.3(release):4fc40b1
NOTICE:  BL31: Built : 15:57:33, May 22 2019
NOTICE:  BL31: G12A normal boot!
U-Boot 2021.07-24133-gf21fc0a44c (Jan 23 2022 - 09:49:20 +0800) radxa-zero
Model: Radxa Zero
SoC:   Amlogic Meson G12A (S905Y2) Revision 28:b (30:2)
DRAM:  2 GiB
MMC:   sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
In:    serial
Out:   serial
Err:   serial
Net:   Net Initialization Skipped
No ethernet found.
starting USB...
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 1 USB Device(s) found
(ROM USB boot)
## Executing script at 08000000
Wrong image format for "source" command
switch to partitions #0, OK
mmc2(part 0) is current device
Scanning mmc 2:1...
Found U-Boot script /boot.scr
2720 bytes read in 1 ms (2.6 MiB/s)
Boot script loaded from mmc 2
370 bytes read in 0 ms
8976111 bytes read in 196 ms (43.7 MiB/s)
20744200 bytes read in 453 ms (43.7 MiB/s)
140891 bytes read in 6 ms (22.4 MiB/s)
513 bytes read in 3 ms (167 KiB/s)
Applying kernel provided DT overlay rk3568-fiq-debugger-uart2m0.dtbo
1322 bytes read in 3 ms (429.7 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 59000000
initrdsize = 0x88f6ef
## Flattened Device Tree blob at 08008000
   Booting using the fdt blob at 0x8008000
ERROR: FDT image overlaps OS image (OS=0x8080000..0x960f000)
SCRIPT FAILED: continuing...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
399 bytes read in 1 ms (389.6 KiB/s)
1:      kernel-4.19.193-36-rockchip-gd05f98887579
Retrieving file: /initrd.img-4.19.193-36-rockchip-gd05f98887579
Retrieving file: /vmlinuz-4.19.193-36-rockchip-gd05f98887579
append: earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init rootfstype=ext4 rootwait  root=UUID=bc933a2b-8da5-428a-a01        c-7673db19a443
Retrieving file: /dtbs/4.19.193-36-rockchip-gd05f98887579/rockchip/rk3566-radxa-cm3-io.dtb
   Loading Ramdisk to 3f770000, end 3ffff6ef ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Loading Device Tree to 000000003f74a000, end 000000003f76f65a ... OK
Cannot setup simplefb: node not found
Starting kernel ...
But it stalls after it.
  1. i have also burned sdcard with the same image but that doesn’t start either.
I also have Python 3 installed as well as pyamlboot, and able to run boot-g12.py in case that’s needed.
i cannot see Raxda via adb.
Could you please help with flashing the eMMC with Ubuntu? Grateful in advance!
Well that is why. You flashed the wrong image. We have quite a few posts with this same issue and we have refactored our image release yet again. Please visit https://github.com/radxa-build/radxa-zero/releases/latest to download your image.
