I’m working with Rock 3A board with SD Card and no eMMC device.
I’m trying to burn OpenHarmony 4.1 (OpenHarmony-v4.1-release -> RK3568 standard system solution (binary)) binaries to target.
I’ve downloaded linux flash driver. flash.x86_64 LD shows that device is present and visible.
However - attempts to flash above mentioned img failed. ./flash.py -i ~/Downloads/OpenHarmony_img -a
Application writes that all is successful - but after power reset, device doesn’t start.
Now it started complaining with
/home/sebastian/Downloads/OpenHarmony_img/driver/bin/flash.x86_64 UL /home/sebastian/Downloads/OpenHarmony_img/MiniLoaderAll.bin
Program Data in /home/sebastian/.config/upgrade_tool
Loading loader...
Loading loader failed,err=-1!
Yes, image list contain MiniLoaderAll.bin and parameters.txt.
Where can I find list of commands or/and images addresses where to upload those images? I could do so following parameters CMDLINE. But I seen that MiniLoaderAll/paramters require additional/different approach (from RKDevTool Windows pictures). rkdeveloptool db MiniLoaderAll.bin works and puts device in maskrom.
But … how to do it all onto SD drive?
