Dim Sidorovich, [2/16/2025 8:27 PM]
It seems I’ve found the main reason of SATA detected problem on Rock 5 ITX
For my opinion, it’s SRIS mode (Separated Reference Clock with Spread Spectrum Clocking) of ASM1164 that is enabled during start up. According to ASM1164 datasheet, pin 14 is a strap pin for SRIS_EN# and low level on it during start up enables the SRIS:
There are pull up and pull down resistors on the board. These are R96000 and R29, respectively, but R29 is “stronger” than R96000, so pin 14 is pulled down:
Unsolder R29 with care. It actually needs good soldering iron. I use Ersa with 102ADLF20 tip at 370 Celsius because one terminal of R29 is on ground plane:
SRIC it’s about independent clock with SSC. Radxa 5 ITX uses Common Reference Clock, not SRIS, so it doesn’t matter whether SSC clock exists or not. The main reason not to use SRIS is a PCIe Common Clock schematic of the board
Out of curiosity, what kernels are they using ? Mine is on 6.12 and boots flawlessly. I admit that some previous mainline kernel attempts did not detect al PCIe and particularly the SATA one, and by then I only attributed this to some flawed PCIe driver.
Armbian’s 6.1.84 vendor kernel definitely exhibits this problem (necessary for transcoding or I’d be on mainline too) - though there is a new kernel available now that may address it.
Now that you’re saying it, it reminds me something. My board had been using vendor 5.10 for a while. When I saw vendor’s 6.1 I tried a few of them and none of them would boot fine due to missing access to SATA. I initially thought they messed up with something that would eventually be fixed, but I got bored. In the mean time someone here helped me figure what I was missing to enable earlycon on mainline and I managed to get mainline to work fine. So maybe in your case reverting to vendor’s 5.10 could also be an option ?
Thank you @sdyspb, has anyone else tried removing R29? Was it a success? I think I can be dangerous enough with a soldering iron to get it off, but probably wouldn’t be able to put it back. I get no SATA love with the current Armbian vendor kernel: 6.1.84-vendor-rk35xx.
Worked for me. I was really tired with it working and then stopping seemingly with system updates.
Sure is nice that it was isolated. Good flux and I was able to remove it with the wrong soldering tip (right one is at work). @sdyspb Thank you.
Worked for me too.
Finally the SATA nightmare is over after trying multiple kernels and setups.
Currently running armbian V25.2.3 - vendor kernel 6.1.99:
before R29 removal: no less than 3 reboots - turn off/on before having the SATA working
after R29 removal: 5 reboots, always working.
Initially the 6.1.99 kernel seemed to work, but it was a delusion at the end.
Level of complexity to remove R29: very low. Third time using a soldering iron in my life and a lens was the only important item I really needed.
@sdyspb thank you for the finding. I took the risk to remove R29 because it was a no return decision: as soon as you remove it, no chance to put it back on the motherboard, but my frustration about SATA was at a point of no return as well.
Honestly this hardware mod makes this board working as you normally would expect.
Here we go: SATA is working, 2 disks in RAID1 mode.
I’m going to say something dirty I’m almost ashamed of, but SMD resistors can even be destroyed with thin pliers for those who are afraid of soldering irons. Just be careful not to pull a track however!
