Hey,
Trying to get 5.10 custom kernel to boot on 4C, but it’s stuck on eMMC initialisation it seems, works fine with default kernel-4.4.154-111-rockchip-g39b306a41b2d, any ideas ? missing kernel options ?
Alex
U-Boot 2021.01-00871-g8b195f4b71 (Jan 28 2021 - 10:37:41 +0000)
SoC: Rockchip rk3399
Reset cause: RST
Model: Radxa ROCK Pi 4C
DRAM: 3.9 GiB
PMIC: RK808
MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... OK
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@fe300000
Hit any key to stop autoboot: 2 ... 1 ... 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:4...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
590 bytes read in 19 ms (30.3 KiB/s)
select kernel
1:.kernel-mainline
2:.kernel-4.4.154-111-rockchip-g39b306a41b2d
Enter choice: 1:.kernel-mainline
Retrieving file: /vmlinuz-5.10.12-rk3399-rock-pi-4c-05c76e1a
15687688 bytes read in 2003 ms (7.5 MiB/s)
append: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk1p5 rootfstype=ext4 init=/sbin/init rootwait
Retrieving file: /rk3399-rock-pi-4c.dtb
55163 bytes read in 24 ms (2.2 MiB/s)
Moving Image from 0x2080000 to 0x2200000, end=3170000
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Device Tree to 00000000f1f0f000, end 00000000f1f1f77a ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.10.12 (gitlab-runner@buster) (aarch64-linux-gnu-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #1 SMP PREEMPT Sat Jan 30 15:07:58 UTC 2021
[ 0.000000] Machine model: Radxa ROCK Pi 4C
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff1a0000 (options '')
[ 0.000000] printk: bootconsole [uart8250] enabled
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000200000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000f7ffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000200000-0x00000000f7ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 22 pages/cpu s49192 r8192 d32728 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 999432
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk1p5 rootfstype=ext4 init=/sbin/init rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x000000003ffbf000-0x000000003ffff000] (0MB)
[ 0.000000] Memory: 3964592K/4061184K available (8510K kernel code, 1688K rwdata, 2868K rodata, 2176K init, 477K bss, 96592K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: .RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] .Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @40080000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000040040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000040050000
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] random: get_random_bytes called from start_kernel+0x334/0x4e8 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000025] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.004415] Console: colour dummy device 80x25
[ 0.004988] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.006117] pid_max: default: 32768 minimum: 301
[ 0.007063] LSM: Security Framework initializing
[ 0.007883] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.008767] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.016508] rcu: Hierarchical SRCU implementation.
[ 0.019755] Platform MSI: interrupt-controller@fee20000 domain created
[ 0.021433] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.024188] smp: Bringing up secondary CPUs ...
[ 0.026742] Detected VIPT I-cache on CPU1
[ 0.026882] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.026926] GICv3: CPU1: using allocated LPI pending table @0x0000000040060000
[ 0.027077] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.029558] Detected VIPT I-cache on CPU2
[ 0.029689] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.029730] GICv3: CPU2: using allocated LPI pending table @0x0000000040070000
[ 0.029857] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.032261] Detected VIPT I-cache on CPU3
[ 0.032389] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.032430] GICv3: CPU3: using allocated LPI pending table @0x0000000040100000
[ 0.032556] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.038074] CPU features: detected: Spectre-v2
[ 0.038496] CPU features: detected: Spectre-v4
[ 0.038770] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.039197] Detected PIPT I-cache on CPU4
[ 0.040864] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.041492] GICv3: CPU4: using allocated LPI pending table @0x0000000040110000
[ 0.043328] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[ 0.056372] Detected PIPT I-cache on CPU5
[ 0.058028] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.058608] GICv3: CPU5: using allocated LPI pending table @0x0000000040120000
[ 0.060271] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.068497] smp: Brought up 1 node, 6 CPUs
[ 0.083571] SMP: Total of 6 processors activated.
[ 0.084104] CPU features: detected: 32-bit EL0 Support
[ 0.084722] CPU features: detected: CRC32 instructions
[ 0.086882] CPU: All CPU(s) started at EL2
[ 0.088255] alternatives: patching kernel code
[ 0.097463] devtmpfs: initialized
[ 0.157956] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.159157] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.160652] pinctrl core: initialized pinctrl subsystem
[ 0.165178] NET: Registered protocol family 16
[ 0.173368] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.174832] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.176390] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.182356] thermal_sys: Registered thermal governor 'fair_share'
[ 0.182388] thermal_sys: Registered thermal governor 'step_wise'
[ 0.188378] cpuidle: using governor ladder
[ 0.192962] cpuidle: using governor menu
[ 0.194840] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.198936] ASID allocator initialised with 65536 entries
[ 0.436978] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.437849] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.438556] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.439300] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.524267] cryptd: max_cpu_qlen set to 1000
[ 0.623450] vcc5v0_sys: supplied by vcc12v_dcin
[ 0.629106] vcc3v3_pcie: supplied by vcc5v0_sys
[ 0.632305] vcc3v3_sys: supplied by vcc5v0_sys
[ 0.635618] vcc_0v9: supplied by vcc3v3_sys
[ 0.636520] vcc5v0_host: supplied by vcc5v0_sys
[ 0.639846] vcc5v0_typec: supplied by vcc5v0_sys
[ 0.646579] iommu: Default domain type: Translated
[ 0.649002] SCSI subsystem initialized
[ 0.650274] usbcore: registered new interface driver usbfs
[ 0.651084] usbcore: registered new interface driver hub
[ 0.651812] usbcore: registered new device driver usb
[ 0.652731] mc: Linux media interface: v0.10
[ 0.653318] videodev: Linux video capture interface: v2.00
[ 0.654239] pps_core: LinuxPPS API ver. 1 registered
[ 0.654772] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.655838] PTP clock support registered
[ 0.658658] Advanced Linux Sound Architecture Driver Initialized.
[ 0.661953] Bluetooth: Core ver 2.22
[ 0.662523] NET: Registered protocol family 31
[ 0.663004] Bluetooth: HCI device and connection manager initialized
[ 0.663724] Bluetooth: HCI socket layer initialized
[ 0.664259] Bluetooth: L2CAP socket layer initialized
[ 0.664892] Bluetooth: SCO socket layer initialized
[ 0.665536] NetLabel: Initializing
[ 0.665951] NetLabel: domain hash size = 128
[ 0.666415] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.667376] NetLabel: unlabeled traffic allowed by default
[ 0.673705] clocksource: Switched to clocksource arch_sys_counter
[ 0.714839] NET: Registered protocol family 2
[ 0.718907] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes, linear)
[ 0.720226] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.723327] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.727849] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.730350] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 0.731880] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 0.734271] NET: Registered protocol family 1
[ 0.742643] PCI: CLS 0 bytes, default 64
[ 0.759615] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.765838] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.774571] Initialise system trusted keyrings
[ 0.777707] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 0.803507] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.033120] NET: Registered protocol family 38
[ 1.033698] Key type asymmetric registered
[ 1.034145] Asymmetric key parser 'x509' registered
[ 1.034870] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.099001] vdd_log: supplied by regulator-dummy
[ 1.102069] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.110487] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 46, base_baud = 1500000) is a 16550A
[ 1.121610] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 47, base_baud = 1500000) is a 16550A
[ 1.123301] printk: console [ttyS2] enabled
[ 1.124239] printk: bootconsole [uart8250] disabled
[ 1.146128] panfrost ff9a0000.gpu: clock rate = 500000000
[ 1.147435] panfrost ff9a0000.gpu: [drm:panfrost_devfreq_init] *ERROR* Couldn't set OPP regulators
[ 1.150861] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.158635] brd: module loaded
[ 1.204313] loop: module loaded
[ 1.212089] libphy: Fixed MDIO Bus: probed
[ 1.212885] usbcore: registered new interface driver rtl8xxxu
[ 1.214448] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.215178] ehci-pci: EHCI PCI platform driver
[ 1.215862] ehci-platform: EHCI generic platform driver
[ 1.220286] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.221824] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 1.223324] ehci-platform fe380000.usb: irq 39, io mem 0xfe380000
[ 1.230836] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.232647] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.233435] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.234178] usb usb1: Product: EHCI Host Controller
[ 1.234715] usb usb1: Manufacturer: Linux 5.10.12 ehci_hcd
[ 1.235247] usb usb1: SerialNumber: fe380000.usb
[ 1.238007] hub 1-0:1.0: USB hub found
[ 1.238583] hub 1-0:1.0: 1 port detected
[ 1.244421] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.246074] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 1.247461] ehci-platform fe3c0000.usb: irq 41, io mem 0xfe3c0000
[ 1.254686] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.256220] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.257067] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.257806] usb usb2: Product: EHCI Host Controller
[ 1.258288] usb usb2: Manufacturer: Linux 5.10.12 ehci_hcd
[ 1.258869] usb usb2: SerialNumber: fe3c0000.usb
[ 1.261342] hub 2-0:1.0: USB hub found
[ 1.261952] hub 2-0:1.0: 1 port detected
[ 1.265414] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.266258] ohci-platform: OHCI generic platform driver
[ 1.268145] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.269798] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 1.271134] ohci-platform fe3a0000.usb: irq 40, io mem 0xfe3a0000
[ 1.328406] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 1.329255] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.329997] usb usb3: Product: Generic Platform OHCI controller
[ 1.330618] usb usb3: Manufacturer: Linux 5.10.12 ohci_hcd
[ 1.331154] usb usb3: SerialNumber: fe3a0000.usb
[ 1.333833] hub 3-0:1.0: USB hub found
[ 1.334343] hub 3-0:1.0: 1 port detected
[ 1.337677] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.339329] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 1.340841] ohci-platform fe3e0000.usb: irq 42, io mem 0xfe3e0000
[ 1.397344] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 1.398230] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.398970] usb usb4: Product: Generic Platform OHCI controller
[ 1.399591] usb usb4: Manufacturer: Linux 5.10.12 ohci_hcd
[ 1.400124] usb usb4: SerialNumber: fe3e0000.usb
[ 1.402881] hub 4-0:1.0: USB hub found
[ 1.403388] hub 4-0:1.0: 1 port detected
[ 1.411844] usbcore: registered new interface driver xpad
[ 1.414678] i2c /dev entries driver
[ 1.443576] rk808 0-001b: chip id: 0x0
[ 1.458869] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.459914] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.462975] vdd_center: supplied by vcc5v0_sys
[ 1.465353] vdd_cpu_l: supplied by vcc5v0_sys
[ 1.466963] vcc_ddr: supplied by vcc5v0_sys
[ 1.469185] vcc_1v8: supplied by vcc5v0_sys
[ 1.472393] vcc1v8_codec: supplied by vcc5v0_sys
[ 1.475012] vcc1v8_hdmi: supplied by vcc5v0_sys
[ 1.477998] vcca_1v8: supplied by vcc5v0_sys
[ 1.480817] vcc_sdio: supplied by vcc5v0_sys
[ 1.483345] vcca3v0_codec: supplied by vcc5v0_sys
[ 1.486271] vcc_1v5: supplied by vcc5v0_sys
[ 1.488855] vcc0v9_hdmi: supplied by vcc5v0_sys
[ 1.491757] vcc_3v0: supplied by vcc5v0_sys
[ 1.492763] vcc_cam: failed to get the current voltage: -EPROBE_DEFER
[ 1.493449] vcc_cam: supplied by vcc3v3_sys
[ 1.495163] vcc_mipi: failed to get the current voltage: -EPROBE_DEFER
[ 1.495928] vcc_mipi: supplied by vcc3v3_sys
[ 1.504950] rk808-rtc rk808-rtc: registered as rtc0
[ 1.506778] rk808-rtc rk808-rtc: setting system clock to 2021-01-30T00:18:46 UTC (1611965926)
[ 1.519481] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.523071] vdd_cpu_b: supplied by vcc5v0_sys
[ 1.534859] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.538244] vdd_gpu: supplied by vcc5v0_sys
[ 1.551861] dw_wdt ff848000.watchdog: No valid TOPs array specified
[ 1.555221] Bluetooth: HCI UART driver ver 2.3
[ 1.555738] Bluetooth: HCI UART protocol H4 registered
[ 1.556237] Bluetooth: HCI UART protocol ATH3K registered
[ 1.557125] usbcore: registered new interface driver bfusb
[ 1.565802] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 200000 KHz, changing to: 408000 KHz
[ 1.570264] random: fast init done
[ 1.571404] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 12000 KHz, changing to: 408000 KHz
[ 1.574395] sdhci: Secure Digital Host Controller Interface driver
[ 1.574944] sdhci: Copyright(c) Pierre Ossman
[ 1.575336] Synopsys Designware Multimedia Card Interface Driver
[ 1.576652] dwmmc_rockchip fe310000.mmc: IDMAC supports 32-bit address mode.
[ 1.576741] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[ 1.577308] dwmmc_rockchip fe310000.mmc: Using internal DMA controller.
[ 1.577312] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.577338] hid: raw HID events driver (C) Jiri Kosina
[ 1.577908] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[ 1.578505] dwmmc_rockchip fe310000.mmc: Version ID is 270a
[ 1.579008] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[ 1.579285] usbcore: registered new interface driver usbhid
[ 1.579287] usbhid: USB HID core driver
[ 1.579503] dwmmc_rockchip fe310000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[ 1.580065] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo
[ 1.580821] rockchip-pinctrl pinctrl: pin gpio3-30 already requested by vcc5v0-host-regulator; cannot claim for ff880000.i2s
[ 1.580825] rockchip-pinctrl pinctrl: pin-126 (ff880000.i2s) status -22
[ 1.580829] rockchip-pinctrl pinctrl: could not request pin 126 (gpio3-30) from group i2s0-8ch-bus on device rockchip-pinctrl
[ 1.580832] rockchip-i2s ff880000.i2s: Error applying setting, reverse things back
[ 1.580841] rockchip-i2s: probe of ff880000.i2s failed with error -22
[ 1.581001] rockchip-i2s ff890000.i2s: Could not register PCM
[ 1.581164] rockchip-i2s ff8a0000.i2s: Could not register PCM
[ 1.581607] u32 classifier
[ 1.581609] input device check on
[ 1.581732] Initializing XFRM netlink socket
[ 1.581880] NET: Registered protocol family 10
[ 1.582307] Segment Routing with IPv6
[ 1.582347] NET: Registered protocol family 17
[ 1.582354] NET: Registered protocol family 15
[ 1.582374] Bridge firewalling registered
[ 1.582435] Bluetooth: RFCOMM socket layer initialized
[ 1.582446] Bluetooth: RFCOMM ver 1.11
[ 1.582451] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.582458] Bluetooth: HIDP socket layer initialized
[ 1.582460] 8021q: 802.1Q VLAN Support v1.8
[ 1.582499] Key type dns_resolver registered
[ 1.582681] registered taskstats version 1
[ 1.582938] dwmmc_rockchip fe310000.mmc: allocated mmc-pwrseq
[ 1.582944] mmc_host mmc0: card is non-removable.
[ 1.584505] Loading compiled-in X.509 certificates
[ 1.586154] Key type ._fscrypt registered
[ 1.587298] Key type .fscrypt registered
[ 1.588305] Key type fscrypt-provisioning registered
[ 1.589498] Key type encrypted registered
[ 1.595717] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.595977] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[ 1.606986] panfrost ff9a0000.gpu: clock rate = 500000000
[ 1.608233] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[ 1.608923] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[ 1.609642] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[ 1.610678] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[ 1.610898] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.611880] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0
[ 1.613071] rockchip-i2s ff890000.i2s: Could not register PCM
[ 1.613790] rockchip-i2s ff8a0000.i2s: Could not register PCM
[ 1.614545] rockchip-i2s ff890000.i2s: Could not register PCM
[ 1.615228] rockchip-i2s ff8a0000.i2s: Could not register PCM
[ 1.616428] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ .[ 1.702983] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 1.843604] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 172
[ 1.847220] mmc0: new ultra high speed SDR104 SDIO card at address 0001
