Not near to the time of people which are trying to help you.
For NVMe SSD, at least 3 years warranty. Just replace a new one if broken here in China. We have done that many times since we test the ssd a lot.
I bought this ssd from Aliexpress, but 15 days have passed since I declared the receipt of the item and I can no longer claim anything. So now I’m going to buy it in my country, but it will cost me more than double. I’m watching Adata XPG GAMMIX S11 Pro 256GB (AGAMMIXS11P-256GT-C) which is on the following page recognized as a device that works: https://wiki.radxa.com/Rockpi4/FAQs
This one is cheaper but I don’t know if it works:
XPG GAMMIX S5 PCIe Gen3x4 M.2 2280 512
https://www.adata.com/jo/specification/587
boot well when other pc flash .img to ssd
if try flash ssd in rockpi = kernel error
Works fine without SDcard, I am now happy, thanks for the code
Kingston 240GB A1000 SSD = PHISON PS5008-E8-10
does not read the kernel SPI boot(works with sdcard)
Samsung 250GB 970 EVO Plus SSD-levy, M.2 2280, PCIe 3.0 x4, NVMe, 3500/2300 MB/s
does not read the kernel SPI (works with sdcard)
Kingston A2000 not work = kernel error
Gigabyte m.2 2280 pciex2 and Intel M.2 NVME works fine and boot spi(not tested armbian)
Hi. I don’t understand the meaning of the concept: does not read the kernel SPI (works with sdcard)
my bad english
not boot without sdcard…with SPI
Is there a way to verify if spi-flash is correctly installed from a rock pi 4 b with micro sd system? What commands should I run in the terminal to verify this?
You have many ssds lol
What are the detail Gigabyte and Intel model?
Yes, i have six M.2 NVME
Gigabyte Model:GP-GSM2NE8128GNTD
Intel SSD 660p Model:SSDPEKNW512GB
boot also SPI without SDcard armbian buster default, two tested with official u-boot
Kingston A2000 M.2 2280 PCIe NVMe
AGAMMIXS5-512GT-c …unstable and heats up strongly
Samung 970EVO PLUS also heats up strongly
maybe some problem with PCIe power management
Hi, I have a doubt. When I format the nvme ssd for the first time to record the debian image for example, should I format the ssd in gtp system? Or it does not matter, if one records the image with the dd function.
So far I had been recording the partition table in msdos.
Thank you
Yes. When you use dd the partition table format is set from the image you write.
I think you may be right there. Thats why some manufactures have heat sink or thermal conductive silicon pad for NVMe.
