Firewalld issues with armbian kernel
While installing cri-o on the Armbian bullseye image I get an error when adding firewalld. I’m not sure if the kernel is missing iptables support or the package is broken.
Looking for suggestions. I’m about to work on recompiling the kernel to see if that’s the issue. Wish this was baked into the kernel.
root@rock-5b-alpha:~# firewall-cmd --state
failed
root@rock-5b-alpha:~# systemctl restart firewalld
root@rock-5b-alpha:~# systemctl status firewalld --no-pager -l
● firewalld.service - firewalld - dynamic firewall daemon
     Loaded: loaded (/lib/systemd/system/firewalld.service; enabled; vendor preset: enabled)
     Active: active (running) since Fri 2022-12-30 00:53:13 MST; 19s ago
       Docs: man:firewalld(1)
   Main PID: 7303 (firewalld)
      Tasks: 2 (limit: 18534)
     Memory: 21.5M
        CPU: 821ms
     CGroup: /system.slice/firewalld.service
             └─7303 /usr/bin/python3 /usr/sbin/firewalld --nofork --nopid
Dec 30 00:53:12 rock-5b-alpha systemd[1]: Starting firewalld - dynamic firewall daemon...
Dec 30 00:53:13 rock-5b-alpha systemd[1]: Started firewalld - dynamic firewall daemon.
Dec 30 00:53:13 rock-5b-alpha firewalld[7303]: ERROR: 'python-nftables' failed:
                                               JSON blob:
                                               {"nftables": [{"metainfo": {"json_schema_version": 1}}, {"add": {"table": {"family": "inet", "name": "firewalld"}}}, {"add": {"table": {"family": "ip", "name": "firewalld"}}}, {"add": {"table": {"family": "ip6", "name": "firewalld"}}}]}
Dec 30 00:53:13 rock-5b-alpha firewalld[7303]: ERROR: COMMAND_FAILED: 'python-nftables' failed:
                                               JSON blob:
I worked around the issue by reverting firewalld back to iptables.
Install Firewalld
apt install firewalld arptables ebtables iptables conmon conntrack conntrackd ipset python-is-python3
Revert firewalld back to iptables
If for some reason you need to revert to the old iptables backend, you can easily do so by setting FirewallBackend in /etc/firewalld/firewalld.conf to iptables, then restart firewalld.
Switching to the legacy tables:
update-alternatives --set iptables /usr/sbin/iptables-legacy
update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy
update-alternatives --set arptables /usr/sbin/arptables-legacy
update-alternatives --set ebtables /usr/sbin/ebtables-legacy
Now the logs of firewalld are clean and I can run iptables -L with successful output
also try, firewall-cmd --state
