[FFmpeg] Introduce FFmpeg-Rockchip for hyper fast video transcoding via CLI
yep, NV12 from a MIPI camera. I don’t know if 12-bit modes (MEDIA_BUS_FMT_SRGGB12_1X12) could trigger this. Note: i think 2016x1080 is 10-bit mode.
I will try to investigate a bit more.
But some feedback:
-- mpp latest commit --
Author: Yanjun Liao <[email protected]>
Date:   Wed Jul 24 15:47:54 2024 +0800
    fix[265e]:Fix the st refernce frame err in tsvc
    This is a bug caused by the mark and use of ltr frames,
    when presence of multiple short temporal refenence frame,
    may lead to errors in reference relationships.
    Change-Id: I1962d81e39b704086a51b4e4098ba3feb64c47c6
    Signed-off-by: Yanjun Liao <[email protected]>
-- rga-multi latest commit --
Author: Yu Qiaowei <[email protected]>
Date:   Thu Aug 29 15:01:34 2024 +0800
    normal: fix wrong full_csc_clip size in memcpy
    This causes the gauss mode to be checked when using full_csc with driver
    versions 1.3.5 and above.
    update to 1.10.1_[3]
    Signed-off-by: Yu Qiaowei <[email protected]>
    Change-Id: I40c3c503c68a77f2c435a8932de0195b447d1d46
-- ffmpeg-rockchip latest commit --
Author: nyanmisaka <[email protected]>
Date:   Wed Oct 23 21:42:03 2024 +0800
    fixup! lavf/rkrga: add RKRGA scale, vpp and overlay filter
    fix nv24/nv42 check on rga2p
    Signed-off-by: nyanmisaka <[email protected]>
works, but dma-buf issue:
[AVFilterGraph @ 0xaaaae71af360] No such filter: ‘scale_rkrga’
Have i missed some build parameters?
works, but dma-buf issue.
Update: the dma-buf issue is only when rendering on screen (ffplay)
In the RK 6.1 kernel, their custom dma-heap driver was removed. It was replaced with the upstream dma-heap driver, which might be the problem. The patch added in my MPP branch will use the DRM allocator instead of dma-heap by default.
As for the missing scale_rkrga filter, check if --enable-rkrga is configured in your FFmpeg.
--enable-gpl --enable-version3 --enable-libdrm --enable-rkmpp --enable-rkrga
This fixed the 1px problem, and possibly the dma-buf issue (i think). Thanks!
PSA: please always use the MPP and RGA branches I mentioned in the Wiki and the latest ffmpeg-rockchip. Those small fixes are carefully selected and verified in Jellyfin Server.
Just for the record, i need to test with your branches, I just tested a uvc webcam that is H264 and H265 with the rockchip branches, and the 1 pixel (looks more 8 pixels) is back.
In order to decode hevc (webcam) i added this:
diff --git a/libavdevice/v4l2-common.c b/libavdevice/v4l2-common.c
index 1926179..d169cba 100644
--- a/libavdevice/v4l2-common.c
+++ b/libavdevice/v4l2-common.c
@@ -57,6 +57,9 @@ const struct fmt_map ff_fmt_conversion_table[] = {
 #ifdef V4L2_PIX_FMT_H264
     { AV_PIX_FMT_NONE,    AV_CODEC_ID_H264,     V4L2_PIX_FMT_H264    },
 #endif
+#ifdef V4L2_PIX_FMT_HEVC
+    { AV_PIX_FMT_NONE,    AV_CODEC_ID_H265,     V4L2_PIX_FMT_HEVC    },
+#endif
 #ifdef V4L2_PIX_FMT_MPEG4
     { AV_PIX_FMT_NONE,    AV_CODEC_ID_MPEG4,    V4L2_PIX_FMT_MPEG4   },
 #endif
I haven’t looked at libavdevice/v4l2-common.c, except to include a patch from rigaya to add nv16/nv24 formats. Please dump a frame as rawvideo and inspect it with YUView. Either it’s a problem in the upstream FFmpeg code, or RK needs to fix their kernel driver.
... -vframes 1 -f rawvideo /path/to/1.yuv
... -vframes 1 -f rawvideo /path/to/2.rgb
FYI, cloned the latest ffmpeg-rockchip, built and ran again, get_format() is choosing NV12 (which is the wrong format, should be yuv420p).
./ffplay -f hevc -vcodec hevc_rkmpp -i ~/ffmpeg_1920x1080_100frames.h265 -loglevel debug
ffplay version 9dbaf5a Copyright (c) 2003-2023 the FFmpeg developers
  built with gcc 12 (Ubuntu 12.3.0-1ubuntu1~22.04)
  configuration: --prefix=/usr --disable-libopenh264 --disable-vaapi --disable-vdpau --disable-decoder=h264_v4l2m2m --disable-decoder=vp8_v4l2m2m --disable-decoder=mpeg2_v4l2m2m --disable-decoder=mpeg4_v4l2m2m --disable-libxvid --disable-libx264 --disable-libx265 --enable-rkmpp --enable-nonfree --enable-gpl --enable-version3 --enable-libmp3lame --enable-libpulse --enable-libv4l2 --enable-libdrm --enable-libxml2 --enable-librtmp --enable-libfreetype --enable-openssl --enable-opengl --enable-libopus --enable-libvorbis --disable-shared --enable-decoder='aac,ac3,flac' --disable-cuvid --enable-rkrga
  libavutil      58. 29.100 / 58. 29.100
  libavcodec     60. 31.102 / 60. 31.102
  libavformat    60. 16.100 / 60. 16.100
  libavdevice    60.  3.100 / 60.  3.100
  libavfilter     9. 12.100 /  9. 12.100
  libswscale      7.  5.100 /  7.  5.100
  libswresample   4. 12.100 /  4. 12.100
  libpostproc    57.  3.100 / 57.  3.100
arm_release_ver of this libmali is 'g6p0-01eac0', rk_so_ver is '6'.
Initialized opengles2 renderer.
[hevc @ 0xffff5c000c20] Opening '/home/rock/ffmpeg_1920x1080_100frames.h265' for reading
[file @ 0xffff5c001290] Setting default whitelist 'file,crypto,data'
[hevc @ 0xffff5c000c20] Before avformat_find_stream_info() pos: 0 bytes read:32768 seeks:0 nb_streams:1
[hevc @ 0xffff5c009a10] nal_unit_type: 32(VPS), nuh_layer_id: 0, temporal_id: 0
[hevc @ 0xffff5c009a10] nal_unit_type: 33(SPS), nuh_layer_id: 0, temporal_id: 0
[hevc @ 0xffff5c009a10] nal_unit_type: 34(PPS), nuh_layer_id: 0, temporal_id: 0
[hevc @ 0xffff5c009a10] nal_unit_type: 19(IDR_W_RADL), nuh_layer_id: 0, temporal_id: 0
[hevc @ 0xffff5c009a10] Decoding VPS
[hevc @ 0xffff5c009a10] Main profile bitstream
[hevc @ 0xffff5c009a10] Decoding SPS
[hevc @ 0xffff5c009a10] Decoding VUI
[hevc @ 0xffff5c009a10] Decoding PPS
[extract_extradata @ 0xffff5c01cde0] nal_unit_type: 32(VPS), nuh_layer_id: 0, temporal_id: 0
[extract_extradata @ 0xffff5c01cde0] nal_unit_type: 33(SPS), nuh_layer_id: 0, temporal_id: 0
[extract_extradata @ 0xffff5c01cde0] nal_unit_type: 34(PPS), nuh_layer_id: 0, temporal_id: 0
[extract_extradata @ 0xffff5c01cde0] nal_unit_type: 19(IDR_W_RADL), nuh_layer_id: 0, temporal_id: 0
[hevc @ 0xffff5c009a10] Format yuvj420p chosen by get_format().
[hevc @ 0xffff5c009a10] Output frame with POC 0.
[hevc @ 0xffff5c009a10] Decoded frame with POC 0. sq=    0B f=0/0
[hevc @ 0xffff5c009a10] nal_unit_type: 1(TRAIL_R), nuh_layer_id: 0, temporal_id: 0
    Last message repeated 2 times
[hevc @ 0xffff5c009a10] Decoding SPSKB vq=    0KB sq=    0B f=0/0
    Last message repeated 44 times
[hevc @ 0xffff5c000c20] All info found
[hevc @ 0xffff5c000c20] After avformat_find_stream_info() pos: 524288 bytes read:524288 seeks:0 frames:50
Input #0, hevc, from '/home/rock/ffmpeg_1920x1080_100frames.h265':
  Duration: N/A, bitrate: N/A
  Stream #0:0, 50, 1/1200000: Video: hevc (Main), 1 reference frame, yuvj420p(pc, bt709, left), 1920x1080 (1920x1088), 0/1, 25 fps, 25 tbr, 1200k tbn
[hevc_mp4toannexb @ 0xffff5c01cde0] The input looks like it is Annex B already
[hevc_rkmpp @ 0xffff5c307780] Format nv12 chosen by get_format().
[hevc_rkmpp @ 0xffff5c307780] Created a RKMPP hardware device
[hevc_rkmpp @ 0xffff5c307780] Decoder flushing
[hevc_rkmpp @ 0xffff5c307780] Wrote 14425 bytes to decoder
[hevc_rkmpp @ 0xffff5c307780] Wrote 16502 bytes to decoder
[hevc_rkmpp @ 0xffff5c307780] Wrote 5682 bytes to decoder
[hevc_rkmpp @ 0xffff5c307780] Noticed an info change
[hevc_rkmpp @ 0xffff5c307780] Decoder options: deint=true afbc=0 fast_parse=true buf_mode=0
[hevc_rkmpp @ 0xffff5c307780] Configured with size: 1920x1080 | pix_fmt: nv12 | sw_pix_fmt: nv12
[hevc_rkmpp @ 0xffff5c307780] Wrote 14920 bytes to decoder
[hevc_rkmpp @ 0xffff5c307780] Received a frame4KB sq=    0B f=0/0
Video frame changed from size:0x0 format:none serial:-1 to size:1920x1080 format:nv12 serial:1
detected 8 logical cores
[ffplay_buffer @ 0xffff540016b0] Setting 'video_size' to value '1920x1080'
[ffplay_buffer @ 0xffff540016b0] Setting 'pix_fmt' to value '23'
[ffplay_buffer @ 0xffff540016b0] Setting 'time_base' to value '1/1200000'
[ffplay_buffer @ 0xffff540016b0] Setting 'pixel_aspect' to value '0/1'
[ffplay_buffer @ 0xffff540016b0] Setting 'frame_rate' to value '25/1'
[ffplay_buffer @ 0xffff540016b0] w:1920 h:1080 pixfmt:nv12 tb:1/1200000 fr:25/1 sar:0/1
[auto_scale_0 @ 0xffff540020f0] w:iw h:ih flags:'' interl:0
[ffplay_buffersink @ 0xffff54001aa0] auto-inserting filter 'auto_scale_0' between the filter 'ffplay_buffer' and the filter 'ffplay_buffersink'
[AVFilterGraph @ 0xffff54003860] query_formats: 2 queried, 0 merged, 1 already done, 0 delayed
[auto_scale_0 @ 0xffff540020f0] picking yuv420p out of 5 ref:nv12 alpha:0
[auto_scale_0 @ 0xffff540020f0] w:1920 h:1080 fmt:nv12 sar:0/1 -> w:1920 h:1080 fmt:yuv420p sar:0/1 flags:0x00000004
[hevc_rkmpp @ 0xffff5c307780] Wrote 48590 bytes to decoder
Created 1920x1080 texture with SDL_PIXELFORMAT_IYUV.
[hevc_rkmpp @ 0xffff5c307780] Wrote 7279 bytes to decoder
[hevc_rkmpp @ 0xffff5c307780] Wrote 7487 bytes to decoder
[hevc_rkmpp @ 0xffff5c307780] Wrote 6723 bytes to decoder
[hevc_rkmpp @ 0xffff5c307780] Wrote 6448 bytes to decoder
ffmpeg_1920x1080_100frames.h265.zip (1.0 MB)
This is expected behavior. The hardware decoders are designed to output semi-planar formats, namely NV12. YUV420P is only used by the software decoder.
ffmpeg-rockchip no longer glues the RGA filter and MPP decoder together, because this does not conform to FFmpeg conventions. You have to use the scale_rkrga filter in your code.
I think i get it, but how do I force auto_scale to pick NV12?
[auto_scale_0 @ 0xffff640022a0] w:1920 h:1080 fmt:nv12 sar:0/1 → w:1920 h:1080 fmt:yuv420p sar:0/1 flags:0x00000004
-vf scale_rkrga=format=nv12
I tried to force nv12 but i got an error:
ffplay_buffer @ 0xffff68001860] Setting 'video_size' to value '1920x1080'
[ffplay_buffer @ 0xffff68001860] Setting 'pix_fmt' to value '23'
[ffplay_buffer @ 0xffff68001860] Setting 'time_base' to value '1/1200000'
[ffplay_buffer @ 0xffff68001860] Setting 'pixel_aspect' to value '0/1'
[ffplay_buffer @ 0xffff68001860] Setting 'frame_rate' to value '25/1'
[ffplay_buffer @ 0xffff68001860] w:1920 h:1080 pixfmt:nv12 tb:1/1200000 fr:25/1 sar:0/1
[AVFilterGraph @ 0xffff680039c0] Setting 'format' to value 'nv12'
[auto_scale_0 @ 0xffff68002770] w:iw h:ih flags:'' interl:0
[Parsed_scale_rkrga_0 @ 0xffff68001dc0] auto-inserting filter 'auto_scale_0' between the filter 'ffplay_buffer' and the filter 'Parsed_scale_rkrga_0'
Impossible to convert between the formats supported by the filter 'ffplay_buffer' and the filter 'auto_scale_0'
ffplay does not support hardware filters. You can use MPV player instead.
MPV is not a choice in my case. Gstreamer and ffplay 4.4.2 decode and render it fine (hw decoder).
I suppressed the filter in ffplay and rendered the NV12 frame as a texture; it works, but the green bar still exists. I need to investigate the NV12 frame format. I will dig into it. Thanks for your information and time.
The green bar means that the actual pitch/stride or offset of the decoder output image does not match the one you calculated. You have to fix it in your code.
@nyanmisaka I’m getting a weird blue screen issue with mpv 0.37.0 using my setup: when I play any of Jellyfin’s test videos(whether AVC, HEVC or AV1, even 8-bit videos) mpv just shows a blue screen. my mpv is run with --hwdec=rkmpp --vd-lavc-o=afbc=on --vf=scale_rkrga=force_yuv=auto and running with drmprime, but mpv keeps throwing errors about [vo/gpu/drmprime] mapping DRM dmabuf failed, which I’m guessing is what’s causing mpv to display blue screen.
My setup is Armbian Noble with kernel compiled from radxa’s 6.1 rkr 4.1 source. Graphics driver is Mali DDK g25p0 with libmali userland g24p0-6, plus vulkan-wsi-layer from ginkage. Kernel has additional dmabuf patches to support system-uncached allocator. Desktop environment is GNOME (Wayland). I have your ffmpeg-rockchip along with jellyfin’s mpp and librga.
Can’t find any information online elsewhere about this blue screen issue with mpv, so would appreciate any guidance!
How to deal with it?
No one else has run into this. Make sure you use the MPP library from my repository, not the official one, which has a bunch of issues.
I get green screen from my cameras using ffmpeg 6.1 from your repository on a rock5b, latest mpp from official repo.
here’s what the NVR is trying:
ffmpeg -hide_banner -loglevel info -c:v hevc_rkmpp -avoid_negative_ts make_zero -fflags nobuffer+genpts+discardcorrupt+igndts -flags low_delay -strict experimental -rtsp_transport tcp -timeout 5000000 -i “rtsp://user:pass@IP:PORT/stream?channel=1&subtype=2” -r 20 -vf hwupload,scale_rkrga=w=1920:h=1080 -y /tmp/tmp.mp4
Input #0, rtsp, from ‘rtsp://user:pass@IP:PORT/stream?channel=1&subtype=2’:
Metadata:
title : Media Server
Duration: N/A, start: 0.016000, bitrate: N/A
Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt470bg/bt470bg/smpte170m), 1920x1080, 20 fps, 40 tbr, 90k tbn
Stream #0:1: Audio: aac (LC), 64000 Hz, mono, fltp
Stream mapping:
Stream #0:0#0:0 (hevc (hevc_rkmpp) → h264 (libx264))
Stream #0:1#0:1 (aac (native) → aac (native))
Press [q] to stop, [?] for help
[hwupload @ 0x55a9de5ca0] A hardware device reference is required to upload frames to.
[Parsed_hwupload_0 @ 0x55a9dea4c0] Query format failed for ‘Parsed_hwupload_0’: Invalid argument
Error reinitializing filters!
Failed to inject frame into filter network: Invalid argument
Error while filtering: Invalid argument
Nothing was written into output file, because at least one of its streams received no packets.
Please contact the maintainer of the NVR software because the called ffmpeg command line is incorrect.
One command is for live view:
ffmpeg -f rawvideo -pix_fmt yuv420p -video_size 1920x1080 -i pipe: -f mpegts -s 1920x1080 -codec:v mpeg1video -q 15 -bf 0 pipe:
and the other one is for detection system:
ffmpeg -hide_banner -loglevel info -c:v hevc_rkmpp -avoid_negative_ts make_zero -fflags nobuffer+genpts+discardcorrupt+igndts -flags low_delay -strict experimental -rtsp_transport tcp -timeout 5000000 -i “rtsp://camera/stream” -r 20 -vf fps=20,scale=1920:1080 -f rawvideo pipe:
what should be the correct params?
The error is not in these two command lines.
 V..... mjpeg_rkmpp          Rockchip MPP (Media Process Platform) MJPEG decoder (codec mjpeg)
RKMPP MJPEG decoder is now available in the latest commits.
