I’ve built Yocto radxa-console-image and got in the boot log.
How to solve this problem?
[ OK ] Started Network Service.
[ OK ] Started Login Service.
Starting Network Name Resolution…
[ OK ] Started LSB: network connection manager.
[ OK ] Started Network Manager.
Starting Hostname Service…
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack…
Starting DNS forwarder and DHCP server…
Starting Permit User Sessions…
Starting Target Communication Framework agent…
[ OK ] Started Permit User Sessions.
[ OK ] Stopped Network Manager.
Starting Network Manager…
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyFIQ0.
[ OK ] Reached target Login Prompts.
[ OK ] Started Weston Wayland Compositor.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started DNS forwarder and DHCP server.
[FAILED] Failed to start Network Manager.
See ‘systemctl status NetworkManager.service’ for details.
[ OK ] Started Hostname Service.
[ OK ] Started Target Communication Framework agent.
[ OK ] Reached target Multi-User System.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Update UTMP about System Runlevel Changes.
Starting Network Manager Script Dispatcher Service…
[ OK ] Created slice User Slice of UID 0.
Starting User Runtime Directory /run/user/0…
[ OK ] Started User Runtime Directory /run/user/0.
Starting User Manager for UID 0…
[ 12.093346] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.094018] dhd_open: Enter ffffffc0dc960000
[ 12.094410]
[ 12.094410] Dongle Host Driver, version 1.579.77.41.2 ®
[ 12.095014] wl_android_wifi_on in 1
[ 12.095327] wl_android_wifi_on in 2: g_wifi_on=0
[ 12.095735] wifi_platform_set_power = 1
[ 12.096118] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 12.096578] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 12.096999] [WLAN_RFKILL]: wifi turn on power. -1
[ OK ] Started Network Manager Script Dispatcher Service.
[ 12.229407] audit: type=1006 audit(1600598644.768:2): pid=595 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
Starting Bluetooth service…
[ 12.395838] blk_update_request: I/O error, dev mmcblk1rpmb, sector 0
[ 12.399989] sdio_reset_comm():
[ 12.416032] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ OK ] Started Bluetooth service.
[ OK ] Reached target Bluetooth.
[ 12.435401] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 12.494985] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 12.501417] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 12.508031] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 12.519270] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 12.532974] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 12.595483] blk_update_request: I/O error, dev mmcblk1rpmb, sector 0
[ OK ] Started User Manager for UID 0.
[ OK ] Started Session c1 of user root.
[ 12.760895] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0)
[ 12.876493] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 102
[ 12.877158] sdioh_start: set sd_f2_blocksize 256
[ 12.877920]
[ 12.877920]
[ 12.877920] dhd_bus_devreset: == WLAN ON ==
[ 12.878653] F1 signature read @0x18000000=0x15294345
[ 12.883660] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x9 pkg:0x2
[ 12.885119] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
[ 12.885792] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 12.895475] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
[ 12.896191] Final fw_path=/system/etc/firmware/fw_bcm43456c5_ag.bin
[ 12.896748] Final nv_path=/system/etc/firmware/nvram_ap6256.txt
[ 12.897267] Final clm_path=/system/etc/firmware/clm_bcmdhd.blob
[ 12.897786] Final conf_path=/system/etc/firmware/config.txt
[ 12.898283] dhd_set_bus_params: set use_rxchain 0
[ 12.898698] dhd_set_bus_params: set txglomsize 36
[ 12.899614] dhdsdio_download_code_file: Open firmware file failed /system/etc/firmware/fw_bcm43456c5_ag.bin
[ 12.900508] _dhdsdio_download_firmware: dongle image file download failed
[ 12.901187] dhd_bus_devreset Failed to download binary to the dongle
[ 12.901745] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 12.902208] dhd_wl_ioctl: returning as busstate=0
[ 12.902624] dhd_dbg_detach_pkt_monitor, 2204
[ 12.903004] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 12.903510] wifi_platform_set_power = 0
[ 12.903846] ======== PULL WL_REG_ON(-1) LOW! ========
[ 12.904321] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 12.904750] [WLAN_RFKILL]: wifi shut off power.
[ 12.905153] wl_android_wifi_on: Failed
[ 12.905493] dhd_open : wl_android_wifi_on failed (-35)
[ 12.905945] dhd_stop: Enter ffffffc0dc960000
[ 12.906325] wl_android_wifi_off in 1
[ 12.906638] wl_android_wifi_off in 2: g_wifi_on=0, on_failure=1
[ 12.907157] dhd_wl_ioctl: returning as busstate=0
[ 12.907575] dhd_dbg_detach_pkt_monitor, 2204
[ 12.907987] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 12.909454] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 12.910103] wifi_platform_set_power = 0
[ 12.910438] ======== PULL WL_REG_ON(-1) LOW! ========
[ 12.910886] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 12.911623] [WLAN_RFKILL]: wifi shut off power.
[ 12.912055] wl_android_wifi_off out
[ 12.912384] dhd_stop: Exit
[ 12.912628] dhd_open: Exit ret=-1
Starting WPA supplicant…
[ 13.128789] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ OK ] Started WPA supplicant.
[ 13.383727] dhd_open: Enter ffffffc0dc960000
[ 13.384149]
says
[[0;1;31m*[[0m NetworkManager.service - Network Manager
Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
Drop-In: /lib/systemd/system/NetworkManager.service.d
`-NetworkManager-ovs.conf
Active: [[0;1;31mfailed[[0m (Result: exit-code) since Sun 2020-09-20 10:44:05 UTC; 7min ago
Docs: man:NetworkManager(8)
Main PID: 626 (code=exited, status=1/FAILURE)
