Trying to debug build problem Faild to build Android 11 AOSP for Rock PI 4AB
The first step is to serialize the build, so I can get the actual build error. But even that is difficult.
I tried the following:
make -j1
m -j1
export SOONG_JOBS = 1
export NINJA_ARGS = “-j1”
modified build/soong/ui/build/config,go, changed the line “ret.parallel = runtime.NumCPU() + 2” to " = 1"
All the above failed to disable the parallelism. There still still lots of soong_build processes running in parallel.
What is the right way to serialize the build?
