Failed to obtain L1 Dcache Refill times in combination with kprobe
The number of L1 Dcache Refills is obtained by directly reading the PMU counter, but the result is always 0. The relevant register enable configuration is as follows:
asm volatile(“mrs %0, pmcr_el0” : “=r”(pmcr));
pmcr |= (1UL << 0) /* E: enable all counters /
| (1UL << 1) /
P: reset event counters /
| (1UL << 2); /
C: reset cycle counter */
asm volatile(“msr pmcr_el0, %0” :: “r”(pmcr));
asm volatile(“isb”);
asm volatile(“MSR PMCNTENSET_EL0, %0” : : “r” (value));
value = 0 & 0x1F;
asm volatile(“MSR PMSELR_EL0, %0” : : “r” (value));
value = 0x03;
asm volatile(“MSR PMXEVTYPER_EL0, %0” : : “r” (value));
