Hi, i’m a noob in linux and Rock PI.
I try to initialize SPI on Rock PI 4 C after applying the configuration procedure given by RADXA.
root@DietPi:/# mraa-gpio version
Version v2.1.0-15-g03d3059 on ROCK Pi 4
root@DietPi:/# ls /dev/spi*
ls: impossible d’accéder à ‘/dev/spi*’: Aucun fichier ou dossier de ce type
root@DietPi:/# sudo ./a.out
Failed to initialize SPI
root@DietPi:/# cat boot/hw_intfc.conf
# Hardware Interface Config
# For more details, check https://wiki.radxa.com/Rockpi4/hardware/devtree_overlays.
# Set "on" to enable the optional hardware interfaces while set "off" to disable.
intfc:pwm0=off
intfc:pwm1=off
intfc:uart2=off
intfc:uart4=off
intfc:spi1=on
intfc:spi2=off
intfc:i2c2=off
intfc:i2c6=off
intfc:i2c7=off
# Devicetree Overlay Enable, uncomment to enable .dtbo under /boot/overlays/.
# EEPROM on I2C2
#intfc:dtoverlay=at24c02
# Serial console on UART2
intfc:dtoverlay=console-on-ttyS2
# Serial console on UART4
#intfc:dtoverlay=console-on-ttyS4
# Dummy spi device on SPI1 for test. Need set: intfc:spi1=on
intfc:dtoverlay=devspi1
# Dummy spi device on SPI2 for test. Need set: intfc:spi2=on
#intfc:dtoverlay=devspi2
# PCIE running on GEN2 mode
#intfc:dtoverlay=pcie-gen2
# ALLNET 4duino B10/B11 two-coloe-led module on 40-pin Header Pin#35 and Pin#36
#intfc:dtoverlay=two-color-led
# waveshare 3.5inch lcd (B v2) on SPI1. Need set: intfc:uart4=off intfc:spi1=on
#intfc:dtoverlay=spi1-waveshare35b-v2
# waveshare 3.5inch lcd (C) on SPI1. Need set: intfc:uart4=off intfc:spi1=on
#intfc:dtoverlay=spi1-waveshare35c
# spi flash on SPI1. Need set: intfc:uart4=off intfc:spi1=on
#intfc:dtoverlay=spi1-flash
#hifiberry-dac
#intfc:dtoverlay=hifiberry-dac
#hifiberry-dacplus on I2C7. Need set: intfc:i2c7=on
#intfc:dtoverlay=hifiberry-dacplus
#enable raspberry pi official 7 inch LCD support
#intfc:dtoverlay=raspberrypi-7-inch-lcd
#enable gt9xx touchpanel
#intfc:dtoverlay=gt9xx
# setting cpu frequency over-2GHz
#intfc:dtoverlay=cpufreq
# Add imx219 camera module support. Need disabled ov5647 camera module.
#intfc:dtoverlay=imx219
# Add ov5647 camera module support. Need disabled imx219 camera module.
#intfc:dtoverlay=ov5647
# Add w1 on GPIO4_D6 to support devices such as DS18B20.
#intfc:dtoverlay=w1-gpio4-30
# can function of waveshare rs485 can hat on SPI1. Need set: intfc:uart4=off intfc:spi1=on
#intfc:dtoverlay=spi1-mcp2515-can0
Help please, i don’t know what to do.
