yoshis
December 2, 2021, 2:41pm
1
Hi, Team,
I failed to execute the following test for Rock3A,
NPU Run Test
Please help me on this error of “Connection timed out”.
root@rock3a:/home/rock/rknn2_ssd_demo_Linux# ./rknn_ssd_demo model/ssd_inception_v2.rknn model/road.bmp
Loading model …
rknn_init …
I RKNN: set log level to 0
model input num: 1, output num: 2
input tensors:
index=0 name=Preprocessor/sub:0 n_dims=4 dims=[1 300 300 3] n_elems=270000 size=270000 fmt=0 type=3 qnt_type=2 fl=0 zp=0 scale=0.007812
output tensors:
index=0 name=concat:0 n_dims=4 dims=[1 1917 1 4] n_elems=7668 size=30672 fmt=0 type=0 qnt_type=2 fl=0 zp=53 scale=0.089455
index=1 name=concat_1:0 n_dims=4 dims=[1 1917 91 1] n_elems=174447 size=697788 fmt=0 type=0 qnt_type=2 fl=0 zp=53 scale=0.143593
rknn_run
E RKNN: [23:18:04.111] failed to submit!, op id: 1, op name: Conv, int status: 0, errno: Connection timed out
rknn_run fail! ret=-1
Thanks.
aghost
December 3, 2021, 12:56am
2
npu probem is a known issue, you can wait for next version image and then check again
yoshis
December 3, 2021, 4:47am
3
Thank you for your quick reply. Good to know that.
jack
December 3, 2021, 7:43am
4
It requires some changes in the u-boot to power on the NPU, we are working on the fix right now.
How is it going,seems i use the latest version debian 10 got the same issue
【system information】
root@rock-3a:/home/rock/rknn_ssd_demo_Linux# uname -a
Linux rock-3a 4.19.193-26-rockchip-gfc6004006609 #rockchip SMP Fri Dec 31 11:49:20 UTC 2021 aarch64 GNU/Linux
【isse details】
root@rock-3a:/home/rock/rknn_ssd_demo_Linux# ./rknn_ssd_demo model/ssd_inception_v2.rknn model/road.bmp
Loading model …
rknn_init …
input tensors:
output tensors:
rknn_run
E RKNN: [16:06:52.095] failed to submit!, op id: 1, op name: Conv:FeatureExtractor/InceptionV2/InceptionV2/Conv2d_1a_7x7/separable_conv2d/depthwise, flags: 0x5, task start: 0, task number: 15, run task counter: 0, int status: 0
Try again with these two commands? https://wiki.radxa.com/Rock3/dev/npu-run-test
# cd /home/rock/rknn_ssd_demo_Linux
# export LD_LIBRARY_PATH=./lib/
Thanks for quick response ,I remember first time I already used this" export LD_LIBRARY_PATH=./lib/" command ,while investigating this issue , I found in the dmesg, got list information
RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
in lshw I found cpu4 is disabled , I’m a new beginner for Rock3a and NPU related knowledge, I want to know if those 2 can cause NPU test failed in my case
in lshw ---- is this CPU 4 means NPU? or GPU?
-cpu:4 DISABLED
description: CPU
product: idle-states
physical id: 5
bus info: cpu@4
in dmesg— finally is RKNPU got memory allocated ?
98217] iommu: Adding device fde40000.npu to group 0
[ 4.603200] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 4.608580] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 4.613425] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[ 4.613512] RKNPU fde40000.npu: Linked as a consumer to regulator.15
[ 4.618213] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
[ 4.623499] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[ 4.628328] RKNPU fde40000.npu: leakage=3
[ 4.633544] RKNPU fde40000.npu: avs=0
[ 4.638899] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
seems not LD PATH issue ,I got the same error,
it is finally working follow the threads Lshw 显示cpu4 disable 是NPU吗?
root@rock-3a:/home/rock/rknn_ssd_demo_Linux# export LD_LIBRARY_PATH=./lib/
Loading model …
rknn_init …
input tensors:
output tensors:
rknn_run
E RKNN: [11:49:35.468] failed to submit!, op id: 1, op name: Conv:FeatureExtractor/InceptionV2/InceptionV2/Conv2d_1a_7x7/separable_conv2d/depthwise, flags: 0x5, task start: 0, task number: 15, run task counter: 0, int status: 0
I’ve did more test, seems the root cause is the dtb file
上次在社区看见有小伙伴问,使用官方系统固件无法开启并正常使用NPU进行rknn_ssd_demo的测试,官方小伙伴更新了内核,但是还是在最后SUBMIT的时候失败。。。
昨天自己研究了一下,并成功在官方固件下开启NPU并正常运行了DEMO。
方法如下:
1.下载radxa的kernel按照教程编译内核
2.如果成功了说明你的环境没问题了
3.修改rock3a分支下的dts文件,[rk3568-rock-3-a.dts]
4.将里面的reserved_memory节点删除,注意是与npu相关的节点
5.将rknpu节点下的预设节点引用删除,只保留supply和status
6.重新编译内核,完成后会生成rk3568-rock-3-a.dtb
7.将编译好的文件使用root权限覆盖3A里/boot/dtbs/同名文件
8.重启设备----大功告成
原理:
应该是官方为NPU预设保留内存时内核报错,导致预设内存失败节点失效,从而使得NPU节点引用内存也失败,所以NPU无法使用,以上代码是参考firefly的3568设备树文件,发现firefly没有使用预设内存,但是可…
thc013
February 9, 2022, 12:20am
10
it is not a uboot fix
it is just the dtb
kernel 4.19.219 2022-01-18
the solution is
what is ?
dts
rknpu_reserved ?!
config
nocp ?!
and you get
/rockchip_test/npu2/rknn_mobilenet_demo /rockchip_test/npu2/model/RK356X/mobilenet_v1.rknn /rockchip_test/npu2/model/dog_224x224.jpg
model input num: 1, output num: 1
input tensors:
index=0, name=data, n_dims=4, dims=[1, 224, 224, 3], n_elems=150528, size=150528, fmt=NHWC, type=UINT8, qnt_type=AFFINE, zp=-13, scale=0.018317
output tensors:
index=0, name=prob, n_dims=4, dims=[1, 1000, 1, 1], n_elems=1000, size=4000, fmt=NCHW, type=FP32, qnt_type=AFFINE, zp=0, scale=1.000000
rknn_run
— Top5 —
155: 0.820312
154: 0.084473
204: 0.084473
252: 0.001647
283: 0.001409
have fun
