Extremely weak signal when using Android on Radxa Zero 3W
I am working on a game streaming client. I chose the Zero 3W because of it’s modern WiFi spec. I would like to use Android because I would like this to be a touch screen device. After much looking, I found this android image that supports the wireless chipset (https://github.com/radxa/manifests/releases/tag/radxa-zero3-we-android11-rkr12-20240111). However, the signal is incredibly weak. When I’m connected within 2 meters of my 5G network, I will get anywhere between 5 and 10 mbps download. Not nearly enough for high fidelity streaming from a PC. The bluetooth is also very weak. Most inputs from my bluetooth controller were dropped, and the ones that were received usually had a delay of ~5 seconds. Is there an updated image, or an image I can build, with improved wireless capabilities?
