Extracting Raw DisplayPort (Rock 5B/CM5)
Hi there,
Say I’m a madman and I want to ignore the alternate mode USB-C DP which is negotiated via the FUSB302 to extract the raw DisplayPort lanes from a USB-C receptacle (DP0/DP1/DP2/DP3/SBU1/SBU2) for debugging. Of course I know this would completely break the spec but I need to get access to the raw data lanes for testing out my own alt mode PD controller, and I really just want access to the DisplayPort lanes straight from the RK3588 GPU - for example, to connect to a DisplayPort connector.
Is there anyway I can modify the kernel and device tree to do so? I’ve already tried the following. Is this all I’d need to do or is there some other requirement/do the drivers not support this in 5.10.160?
https://github.com/radxa/kernel/blob/d7f6b85f6fcfdf510f382174bf08368e73fb9287/drivers/phy/rockchip/phy-rockchip-usbdp.c#L490
What I’ve tried so far is the following via sudo armbian-add-overlay usbdpmux.dts
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&usbdp_phy0>;
        __overlay__ {
            rockchip,dp-lane-mux = <3 2 0 1>;
Is anything else required to be done here like nuking the TCPM or is this one overlay enough to give me access to the raw DP/AUX lanes from the SoC?
It seems strange that on a compute module lineup (CM3/CM4) there are no drivers to support a standard DisplayPort output instead of over Alt Mode. This would give the designers a bit more flexibility in terms of using an external PD controller, rather than being stuck with the onboard FUSB302.
You can refer the NX5 schematic
https://dl.radxa.com/nx5/
and the NX5 IO board dts for the directly DP output.
Thanks for your reply.
We’ve tried making the following changes below but unfortunately, I wasn’t able to get it to work yet. I need to mux the specific DisplayPort data lanes from the RK3588 GPU as follows, onto the USB-C port pins in a <3 2 0 1> setup, which then will feed into my test PCB. I want to obviously ignore alt mode just for testing purposes and force the DP lanes on the connector.
kernel/drivers/phy/rockchip/phy-rockchip-usbdp.c at d7f6b85f6fcfdf510f382174bf08368e73fb9287 · radxa/kernel · GitHub
These are the changes we made to the device tree. Do they look correct? I need to make sure I’m forcing DP and I need to mux the data lanes as per the rockchip,dp-lane-mux flag below:
  12   │ index fcfc141a9ae9..ba04f955ef82 100644
  13   │ --- a/arch/arm64/boot/dts/rockchip/rk3588s-radxa-cm5-io.dts
  14   │ +++ b/arch/arm64/boot/dts/rockchip/rk3588s-radxa-cm5-io.dts
  15   │ @@ -267,77 +267,10 @@ dsi1_backlight: dsi1-backlight {
  16   │  &i2c6 {
  17   │     status = "okay";
  18   │     pinctrl-names = "default";
  19   │     pinctrl-0 = <&i2c6m3_xfer>;
  20   │
  21   │ -   usbc0: fusb302@22 {
  22   │ -       compatible = "fcs,fusb302";
  23   │ -       reg = <0x22>;
  24   │ -       interrupt-parent = <&gpio0>;
  25   │ -       interrupts = <RK_PC4 IRQ_TYPE_LEVEL_LOW>;
  26   │ -       int-n-gpios = <&gpio0 RK_PC4 GPIO_ACTIVE_LOW>;
  27   │ -       pinctrl-names = "default";
  28   │ -       pinctrl-0 = <&usbc0_int>;
  29   │ -       vbus-supply = <&vbus5v0_typec>;
  30   │ -       status = "okay";
  31   │ -
  32   │ -       ports {
  33   │ -           #address-cells = <1>;
  34   │ -           #size-cells = <0>;
  35   │ -           port@0 {
  36   │ -           reg = <0>;
  37   │ -           usbc0_role_sw: endpoint@0 {
  38   │ -               remote-endpoint = <&dwc3_0_role_switch>;
  39   │ -               };
  40   │ -           };
  41   │ -       };
  42   │ -
  43   │ -       usb_con: connector {
  44   │ -           compatible = "usb-c-connector";
  45   │ -           label = "USB-C";
  46   │ -           data-role = "dual";
  47   │ -           power-role = "dual";
  48   │ -           try-power-role = "sink";
  49   │ -           op-sink-microwatt = <1000000>;
  50   │ -
  51   │ -           sink-pdos =
  52   │ -               <PDO_FIXED(5000, 1000, PDO_FIXED_USB_COMM)>;
  53   │ -           source-pdos =
  54   │ -               <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)>;
  55   │ -
  56   │ -           altmodes {
  57   │ -               #address-cells = <1>;
  58   │ -               #size-cells = <0>;
  59   │ -
  60   │ -               altmode@0 {
  61   │ -                   reg = <0>;
  62   │ -                   svid = <0xff01>;
  63   │ -                   vdo = <0xffffffff>;
  64   │ -               };
  65   │ -           };
  66   │ -
  67   │ -           ports {
  68   │ -               #address-cells = <1>;
  69   │ -               #size-cells = <0>;
  70   │ -
  71   │ -               port@0 {
  72   │ -                   reg = <0>;
  73   │ -                   usbc0_orien_sw: endpoint {
  74   │ -                       remote-endpoint = <&usbdp_phy0_orientation_switch>;
  75   │ -                   };
  76   │ -               };
  77   │ -
  78   │ -               port@1 {
  79   │ -                   reg = <1>;
  80   │ -                   dp_altmode_mux: endpoint {
  81   │ -                       remote-endpoint = <&usbdp_phy0_dp_altmode_mux>;
  82   │ -                   };
  83   │ -               };
  84   │ -           };
  85   │ -       };
  86   │ -   };
  87   │ -
  88   │     hym8563: hym8563@51 {
  89   │         compatible = "haoyu,hym8563";
  90   │         reg = <0x51>;
  91   │         #clock-cells = <0>;
  92   │         clock-frequency = <32768>;
  93   │ @@ -349,28 +282,16 @@ hym8563: hym8563@51 {
  94   │     };
  95   │  };
  96   │
  97   │  &usbdp_phy0 {
  98   │     status = "okay";
  99   │ -   orientation-switch;
 100   │ -   svid = <0xff01>;
 101   │ -   sbu1-dc-gpios = <&gpio3 RK_PC4 GPIO_ACTIVE_HIGH>;
 102   │ -   sbu2-dc-gpios = <&gpio3 RK_PD4 GPIO_ACTIVE_HIGH>;
 103   │ -
 104   │ -   port {
 105   │ -       #address-cells = <1>;
 106   │ -       #size-cells = <0>;
 107   │ -       usbdp_phy0_orientation_switch: endpoint@0 {
 108   │ -           reg = <0>;
 109   │ -           remote-endpoint = <&usbc0_orien_sw>;
 110   │ -       };
 111   │ +   rockchip,dp-lane-mux = <3 2 0 1>;
 112   │ +};
 113   │
 114   │ -       usbdp_phy0_dp_altmode_mux: endpoint@1 {
 115   │ -           reg = <1>;
 116   │ -           remote-endpoint = <&dp_altmode_mux>;
 117   │ -       };
 118   │ -   };
 119   │ +&route_dp0 {
 120   │ +   status = "okay";
 121   │ +   connect = <&vp2_out_dp0>;
 122   │  };
 123   │
 124   │  &dp0 {
 125   │     status = "okay";
 126   │  };
  11   │ diff --git a/arch/arm64/boot/dts/rockchip/rk3588s-radxa-cm5-io.dts b/arch/arm64/boot/dts/rockchip/rk3588s-radxa-cm5-io.dts
  12   │ index ba04f955ef82..92b8482f64e1 100644
  15   │ @@ -651,20 +651,10 @@ &usbdrd3_0 {
  16   │
  17   │  &usbdrd_dwc3_0 {
  18   │     dr_mode = "otg";
  19   │     extcon = <&u2phy0>;
  20   │     status = "okay";
  21   │ -
  22   │ -   usb-role-switch;
  23   │ -   port {
  24   │ -       #address-cells = <1>;
  25   │ -       #size-cells = <0>;
  26   │ -       dwc3_0_role_switch: endpoint@0 {
  27   │ -           reg = <0>;
  28   │ -           remote-endpoint = <&usbc0_role_sw>;
  29   │ -       };
  30   │ -   };
  31   │  };
  32   │
  33   │  &usbhost3_0 {
  34   │     status = "okay";
  35   │  };
For anyone interested in helping debug, I’ve also uploaded my schematics below:
I did notice there is a HPD node there, whereas in my setup I removed the HPD node.
Do I need to drive this high or can I force hotplug in some way? EDIT: Looks like this needs to be driven high or forced, will report back soon.
Best
Ben
Well, this can be closed. Ended up getting DisplayPort working with my PD Alt Mode ext con. Indeed, the HPD GPIO was required.
Thanks
Ben
