I have Crucial MX500 1 TB connected externally to USB 3.0 via adapter.
When this disk operates on PC it goes up to 300-500 MB/s write on the same adapter (Unitek or LogiLink).
The file system is NTFS.
However on my Rock Pi (and the drive is connected to USB 3.0) the drive does not go above 30-32 MB/s write speed.
Is there any solution to make the drive work with higher speeds?
EDIT: This happens when I am using Samba and copying file from PC to disk connected to this Rock Pi - so samba is first suspect (it is 1 Gb Ethernet), and NTFS support is second suspect. Locally the drive is 154 MB/s - writable.
