Anybody knows the manufacturer/part number of the eSATAp connector on Penta Sata Hat? I accidentally squashed it and want to buy a part from digikey or mouser or alibaba to replace it.
Any esata with power will do. They also called “power esata”
Thank you for your advice. But this type of connector seems to be rare nowadays. It seems the connector on Penta Sata Hat is a dual power esata/usb connector (esatapd) with 12V power supply in addition to USB 5V. I have checked digikey and mouser, no branded supplier such as amphenol, te, or molex has esatapd connector on their list. Also the footprint is probably not compatible to each other since esatapd is not an official extension from sata standard. It seems to be an “invention” from Taiwain mobo connector manufacturer. Specifically I found a US patent granted to Taiwin Electronics for esatapd connector design. But I have no idea where to buy components from this manufacturer.
Erm… You are going a bit too faaar,
https://www.amazon.com/CableCreation-Power-Esata-eSATAp-Adapter/dp/B01ESJONAQ/
This cable not that rare.
Thank you so much. But I meant the on-board connector, the receptacle, not the plug at the end of cable.
I did mean this connector. But I meant the on-board receptacle.
The only one I could find on the Internet is a DeLock part which has been discontinued for a long time. Noticing two wide pins right behind the positioning bosses.These two pins carries 12V power supply and the connector is mentioned as eSATApd by DeLock (d for dual power). Most parts from other vendors do not have these two pins. They are either a eSATA + USB combo connector which has only +5V power supply from USB VBUS, or a standard, signal-only eSATA connector without any power supply at all.
The connector on the Penta Sata Hat is a eSATApd connector which carries dual power. It is very convenient for the users. I don’t know why the eSATApd cable is still common on the market but the receptacle connector is really rare. Really weird.
Does anyone here have the priviledge to check the BOM list of the board, and tell me the manufacturer/part number? I need a replace part.
Thanks.
Did you get one?
I saw some of them on aliexpress.
I saw the Delock ones.
If you didnt get one I have a spare one of the boards you can have for postage.
My issue is I want to use eSATAp connection to a 5th SSD SATA drive in a case for protection and the connector is just placed really badly.
Does anyone makes a 90 degree male /female eSATAp connector to make things managable or neater?
Does anyone have a wire diagram of the eSATAp connector so I could convert it to usb c?
The name eSATA, e means external, in our design, this port is for HDD rescue/backup/transfer directly. It’s not intended for HDD storage though you can do it.
Do you know how to enable this port to be used as an additional drive? as I would like to attempt to add an additional HDD. Thanks.
I would like to understand the part at the drive-end of the cable that comes with the Penta SATA hat. It looks like a sata adapter, likely normal 22 pin female, and then nothing for power. Is there supposed to be something that plugs in for power? If so what is it and how does it work.
